after i get my car running ill be starting an rb30/26 project.
on that motor i want to run a pretty large turbo (havent decided which yet), and i was thinking of a staged turbo setup with something smaller to build up exhaust flow and give me some low-mid power before the larger one spools, which in turn will make it start spooling earlier.
im no mechanical genius so im coming to you guys for some guidence on how i could make this work as im not the type of guy who would walk into a workshop and say "i want this, that, those" and flop $30k on the table. most of the work will be done by myself so its important that i understand how it all works.
the motor is going to be used for drags. i know i could use nitrus but i'd rather something different.
i'd appreciate your thoughts on running this kind of setup too.
thanks guys.
https://www.sau.com.au/forums/topic/112869-staged-turbos/
I would forget staged turbochargers as well . One thing they do garantee is high exhaust manifold pressure at low/med revs because of the primary turbos small turbine and housing . Also the changeover from primary to secondary is difficult to achieve smoothly . What is supposed to happen is the larger secondary turbine gets a small but increasing amount of exhaust flow to spin it up to useful speed . Its nearly impossible to do this without robbing the primary turbine of enough energy to slow it and the engines torque development . The secondary compressor has to attempt to come on line and provide enough volume and pressure to take up the supercharging effort smoothly . It quite complex with the secondary compressor having air valves to prevent air from the primary compressor backfeeding to atmosphere through its air inlet . Far more trouble than its worth and very expensive to develop and manufacture .
Subaru tried it with the B4 and ended up prefering the larger EJ25 with its twin scroll or split pulsed single turbo . One of the late Mazda Rotaries (was it ser 5 or 6 ?) used it but it ended up being so complex and unreliable that no one wanted to know about it when it acted up . In fact one of the rev head magazines had an article about how to convert them back to a Hybrid Hitachi HT-18S / TO4B single turbo .
I think the most successful solution is to have as many cubic inches as is economic to build and if necessary turbocharge that . The RB30 should make enough torque off boost to make a Skyline feel pretty good (provided final drive gearing is not too short) and spool the sort of turbos that make BIG power if everything else is made to support it .
Cheers A .
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2081335
There is a 3 litre stroker kit, but that involves lots of money (os giken)
Your best and cheapest bet is to go an rb30 bottom end with a 25 or 26 head.
If you want something that revs a bit better, get an rb26 block and get a stroker kit for that (tomei or hks 2.8) However, that will still cost you a fair whack of dollars
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2081736
Just buy a VL rb30 bottom end , give it a light hone, some used pistons and rings and bolt a RB26 cil head on to it all up $2000 . Get a big high mount turbo, rev it to 10,000 rpm and you will have a very quick R33 gst , should last for a couple hundred k's no problem.
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2081821
  Tommyk said:
Jerry but rev a stock head and bottom end 26 and it wont last very long at 10000 rpm either.
I doubt the rb30 would last a few hundred kms at 10000 rpm. One go and I assume it would be a big bang. And that would be on the dyno while tuning it :)
Who said anything about tuning Tom?
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2081909
Forget about staged turbos, if the manufacturers cannot get it to work properly with all their resources, you or I have less than zero chance of making it work either.
But staging a turbo and a supercharger has been proven to work very well. Nissan did it on a production engine, Audi did it on a production engine, and now the 2006 model VW Golf GTI in Europe has both a turbo and a supercharger fitted to it.
I have done it successfully too, and Stocky is in the final stages of building a turbo + supercharger system on an RB30DE. So stay tuned...
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2082017
whatever it costs to have an unbreakable motor... im willing to spend around the 25-30k mark including the turbo.
it wont be a straight up 2 week build.. ill be building it over time as its autumn and my money tree is losing all its leaves :thumbsup:
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2084330
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
