after i get my car running ill be starting an rb30/26 project.
on that motor i want to run a pretty large turbo (havent decided which yet), and i was thinking of a staged turbo setup with something smaller to build up exhaust flow and give me some low-mid power before the larger one spools, which in turn will make it start spooling earlier.
im no mechanical genius so im coming to you guys for some guidence on how i could make this work as im not the type of guy who would walk into a workshop and say "i want this, that, those" and flop $30k on the table. most of the work will be done by myself so its important that i understand how it all works.
the motor is going to be used for drags. i know i could use nitrus but i'd rather something different.
i'd appreciate your thoughts on running this kind of setup too.
thanks guys.
https://www.sau.com.au/forums/topic/112869-staged-turbos/
I would forget staged turbochargers as well . One thing they do garantee is high exhaust manifold pressure at low/med revs because of the primary turbos small turbine and housing . Also the changeover from primary to secondary is difficult to achieve smoothly . What is supposed to happen is the larger secondary turbine gets a small but increasing amount of exhaust flow to spin it up to useful speed . Its nearly impossible to do this without robbing the primary turbine of enough energy to slow it and the engines torque development . The secondary compressor has to attempt to come on line and provide enough volume and pressure to take up the supercharging effort smoothly . It quite complex with the secondary compressor having air valves to prevent air from the primary compressor backfeeding to atmosphere through its air inlet . Far more trouble than its worth and very expensive to develop and manufacture .
Subaru tried it with the B4 and ended up prefering the larger EJ25 with its twin scroll or split pulsed single turbo . One of the late Mazda Rotaries (was it ser 5 or 6 ?) used it but it ended up being so complex and unreliable that no one wanted to know about it when it acted up . In fact one of the rev head magazines had an article about how to convert them back to a Hybrid Hitachi HT-18S / TO4B single turbo .
I think the most successful solution is to have as many cubic inches as is economic to build and if necessary turbocharge that . The RB30 should make enough torque off boost to make a Skyline feel pretty good (provided final drive gearing is not too short) and spool the sort of turbos that make BIG power if everything else is made to support it .
Cheers A .
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2081335
There is a 3 litre stroker kit, but that involves lots of money (os giken)
Your best and cheapest bet is to go an rb30 bottom end with a 25 or 26 head.
If you want something that revs a bit better, get an rb26 block and get a stroker kit for that (tomei or hks 2.8) However, that will still cost you a fair whack of dollars
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2081736
Just buy a VL rb30 bottom end , give it a light hone, some used pistons and rings and bolt a RB26 cil head on to it all up $2000 . Get a big high mount turbo, rev it to 10,000 rpm and you will have a very quick R33 gst , should last for a couple hundred k's no problem.
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2081821
Jerry but rev a stock head and bottom end 26 and it wont last very long at 10000 rpm either.
I doubt the rb30 would last a few hundred kms at 10000 rpm. One go and I assume it would be a big bang. And that would be on the dyno while tuning it :)
Who said anything about tuning Tom?
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2081909
Forget about staged turbos, if the manufacturers cannot get it to work properly with all their resources, you or I have less than zero chance of making it work either.
But staging a turbo and a supercharger has been proven to work very well. Nissan did it on a production engine, Audi did it on a production engine, and now the 2006 model VW Golf GTI in Europe has both a turbo and a supercharger fitted to it.
I have done it successfully too, and Stocky is in the final stages of building a turbo + supercharger system on an RB30DE. So stay tuned...
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2082017
whatever it costs to have an unbreakable motor... im willing to spend around the 25-30k mark including the turbo.
it wont be a straight up 2 week build.. ill be building it over time as its autumn and my money tree is losing all its leaves :thumbsup:
https://www.sau.com.au/forums/topic/112869-staged-turbos/#findComment-2084330
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
