BBGTR Posted April 9, 2006 Share Posted April 9, 2006 (edited) I need to completely flush my ATTESSA system and it has been recommended that I use this fluid. Where can I get Castrol Transmax Z ATF in Melbourne - seems the usual places don't have it. Regards Andrew Edited April 9, 2006 by BBGTR Link to comment https://www.sau.com.au/forums/topic/112882-castrol-transmax-z-atf/ Share on other sites More sharing options...
BBGTR Posted April 10, 2006 Author Share Posted April 10, 2006 Found some - Burson's in Richmond.... Link to comment https://www.sau.com.au/forums/topic/112882-castrol-transmax-z-atf/#findComment-2083346 Share on other sites More sharing options...
Trex101 Posted April 10, 2006 Share Posted April 10, 2006 (edited) I need to completely flush my ATTESSA system and it has been recommended that I use this fluid.Where can I get Castrol Transmax Z ATF in Melbourne - seems the usual places don't have it. Regards Andrew Castrol Transmax Z is just a normal synthetic Dexron III ATF, if budget is no issue, Redline synthetic high temp would be a very good bet, meets dexron III, Mercon V & GL-4 spec. The best money can buy. Redline Synthetic High Temp Edited April 10, 2006 by Trex101 Link to comment https://www.sau.com.au/forums/topic/112882-castrol-transmax-z-atf/#findComment-2083718 Share on other sites More sharing options...
BBGTR Posted April 12, 2006 Author Share Posted April 12, 2006 Castrol Transmax Z is just a normal synthetic Dexron III ATF, if budget is no issue, Redline synthetic high temp would be a very good bet, meets dexron III, Mercon V & GL-4 spec. The best money can buy.Redline Synthetic High Temp Thanks dude, I'll go down to Oil World in Moorabbin here in Melbourne and get some - I get my Redline Gearbox oil from there. Regards Andrew Link to comment https://www.sau.com.au/forums/topic/112882-castrol-transmax-z-atf/#findComment-2089652 Share on other sites More sharing options...
BOOSTD Posted May 6, 2006 Share Posted May 6, 2006 Advan reccommended using Dextron III. I spent big on Transmax Z =( Link to comment https://www.sau.com.au/forums/topic/112882-castrol-transmax-z-atf/#findComment-2144948 Share on other sites More sharing options...
