Hi-flow cat 3" $250 -300. I have no cat, which is better than gutting it, an empty cat still creates turbulance, which is bad. You can buy a cat remover, which comes with tags to add a cat exterior over a straight bit of pipe.
See'ya:burnout:
See'ya:burnout:
Is this legal?
T.
Any removal of a cat is ilegal!(These cat remover pipes are for competition use only)
Also it's $250-$300 + fitting cause they aren't bolt in items!!
Carsound is a good brand of high flow cats!!, and they are true high flow cats!(have fitted hundreds of the them, mostly to Holden's and Ford's though but have done a few Skyline's, Supra's , Soarer's and a few other imports!
MEGA
And for all those who think that the term "high flow cat" is an oxy-moron.
Here is some tests done on a LS-1 chev(sorry couldn't find a Skyline one) with modifying the standard cats and comparing them to high flow ones on the flow bench.
Here is the link:
http://www.installuniversity.com/install_u...on11.122001.htm
Also I personaly couldn't run my car without a catalytic converter as the power increase would only be approx 3%, and even less compared to a high flow catalytic converter, this also would make any car a rolling defect notice and make it even more destructive to the atmosphere!
MEGA
I had a high-flow cat in mine, and since it's removal have had no issues and the car is producing more power. I had to remove it to run rotational idle and anti-lag, I don't recommend this approach to most people, just those after serious power. And yes there are legal and enviromental rammifications.
See'ya:burnout:
i just bought a 3 inch catco cat which should be hear next week.
cost me $170 brand new. i just got to get the flanges put on.
its a stainless steal one too. will let u know how it is. but i will not be able to tell the difference as it will be on the car from the very start once it gets started up.
silyRB
Guest sirmx6
Bit confused on the difference between gutting a cat and fitting a 3-inch hi flow cat.
What is the advantage / disadvantage of doing either ??
When you say gutting the cat, does that mean the standard cat or an aftermarket one ??
Reason i ask is that i have a 3-inch dump into a 2.5 inch cat and then 3 inch piping from the cat back.
Which one is going to work better for me - gutting the 2.5inch cat or fitting a 3inch high flow ??
i think by gutting he is refering to just having a straight through pipe with the cat casing on the outside to keep it looking leagal
i think u should go the 3" pipe, i always like doing something properly from the start unless its way out of reach. if u have to pay that little bit extra then do it otherwise u will pay for a 2.5, then want a 3" and so your paying more than u originally would of
Originally posted by BATMBL
Hey guys,
I know the guy who produces the parts for CATCO (Jappsport uses their cats for compliance and he comes by to sell them to us), so I can get any1 thats interested, a CATCO 3 INCH HI-FLOW CAT with the flanges for $160. You can come and pick it up from where I work in liverpool, sydney (Jappsport) or i can ship it to you interstate for a little extra.
I can also get 3 inch dump+front pipes (one piece, easy to bolt on) for r33 and r32 for $260. Ā
If you want a 3 inch stainless steel pipe, its $100 extra. Ā
I can also supply you with front+dump pipes for 180sx.
These I get from the same person that produces the cats for CATCO.
cheers
BATMBL: How about the above parts for an R34?
Can you get the CATCO cat and dump / font pipes? And are the prices similar?
I already have a 3.5 inch cat-back exhaust. I am assuming this stuff would complete my exhaust system?
Thanks!
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... šŸ˜›
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. šŸ”¹ Initially, he quoted me $3,500 - $4,500. šŸ”¹ First invoice: $5,315 (already above the quote). šŸ”¹ Second invoice: $1,375. šŸ”¹ Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like Iā€™m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! šŸ™ Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
Ɨ
Ɨ
