Oil was DEFINITELY on the track BEFORE Shane raced. As witnessed by the total lack of oil under his car and the fact that he went straight as a die on the next pass.
Though that might have been the case...not the first time that's happened at WSID from what I've heard.
  • Replies 57
yeah, unfortunately thats what happened to my camera man. he dropped the camera when i was 45 degrees to the right wall.
no one seemed to actually get many pics of the car all weekend. although i had lots of verbal praise which was good.
I got plenty of pics of it mate - just nothing spectacular.
havnt read all three pages or so..
ANyways nice run to the yellow s15.. hehe nearly had an accident, yet u still ran a really good time..
Whats done to your car??
Also what happened to TUFGTR!! did he blow something?
RB25DET conversion - 3 speed auto - hi mount single - ET Streets.
TUFGTR only had one or two passes - wasnt sounding healthy on one pass. Dunno if it's broken or not though
Quite a few cars were having traction issues.
The track was only re-surfaced (all rubber scraped back to base surface from start line to 1000ft) about 2wks ago. They are probably preparing for the Nitro Champs in May, unfortunately that means it will be May before the track is back to 100%.
congrats to Brett for running so many 10's. I had no idea you were doing so well :laugh::( Given track conditions i am sure that single digit pass is just around the corner :D:D
What times did the S15 run??? had no idea it to was RB powered :D:miner:
on that VN's last ran it bent the hell out of the lower rear control arms. Guy was lucky it lost fuel pressure and he backed off at half track cause it a very ugly and out of control up until the time he backed off.... he ended up running 11.9 at 119mph.
Edited by ido09s
mann... so annoyed.. the girls were only running low 13s!!! thats $500 i could have put back into the car!!! dayummm!!!
brett!! LOVE your car!!!! seriously!! Can't believe i finally got to see you run!!!! hi5 uncle buster!! now to follow in your footsteps! :P
Stace! Paul! Awesome to see you guys again!! can't wait to see twogs out there :ermm:
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
