Hey Fellow wagoneers,
I was doing some searching to find out exactly what kit i've got & this is what i've found. They have the Dayz kit as well as some others. I don't know if you have come across this site before, but it's got some nice kits just begging to be imported. :)
Freeway Dolphin homepage
I also noticed the Nissan Avenir's, I'venever seen them before, But there on there...... similar to stagea but with an SR20DET..... does anyone know if these are being imported & if so where can i get one!
https://www.sau.com.au/forums/topic/112951-stagea-bodykit-site/
Probably one of my favorite kits over the stock dayz kit.
Bit too $$ for me at the moment though, too performance oriented...
By the way, you could have asked anyone here, we all knew you have the dolphin aeroform kit. There are 3 s2's on here with that kit, its a very nice kit.
  • 1 year later...
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
