I am currently running 13psi on mine. I will be getting a tune pretty soon so might bump it up to 14psi, but I'm not willing to push it higher than that. Personally I am pretty stoked at the performance I am getting at 13psi so I don't feel the need to go much higher.
I have killed 2 X R34GTT turbos at 12 psi.
They don't make any more over a genuine 12 psi anyway, they heat soak the air so much you get detonation. So you have to retard the ignition timing and loose all the power you gained.
:) cheers :)
more boost doesnt mean more power
more boost means more power (well airflow) only when you are still in the efficency zone for the compressor wheel. past 12psi as others have said and its off the efficeny zone, so you just dial in more and more heat and it goes bang
90% of all stock turbos will blow at a genuine 15 psi if run there often.
It's not boost alone that makes them blow. It's boost and heat which makes the exhuast wheel delaminate.
Do a seach and see. This topic has been covered a 'few' times before.
Hey there,
So for all you guys that have had the turbo die on you, was the turbo ever subjected to continuous high heat levels, i.e., drifting, track racing, or continuous on/off throttle runs through the gears in short periods of time?
The R34 turbo's must have a small efficiency range if they start to die around 12psi, just seems low to me, and a very quick drop off. You'd be able to verify this on a dyno by looking at inlet temps at various psi.
The R33 turbo on my RB20 does make a fair bit more on the dyno at 1Bar (14.7psi) as opposed to 0.8bar (12psi), but it was on different dyno's, but using the same shootout mode. Inlet temps did not skyrocket either. R33 turbo's seem to be still good at 15ish- psi..... whereas R34's seem to go off at 12.
Fixxxer
Also shaft speed can be the killer. So just being on full song for a long long period can make it fail. Have seen a HKS 2530 fail with steel wheel so its possible to kill others also.
Fixxxer....
What power is the R33 turbs making on your Rb20?
Made 229HP@wheels at 0.82bar, held that all the way to redline I'm sure, with a ProfecA.
Think it made 247HP at 1bar, that was with the original owner, not the guy I bought it off. Might have been a few years ago but the graphs in the car.
Fixxxer
okay.
So thats 170rwkw at 0.8 bar
and 184rwkw at 1.0 bar.
the R34 Turbo on my car (which is an R34) made 200rwkw on 12 psi (0.8 bar) which is about 270rwHP
The R34 turbos are reasonably good for about 20 rwkw more on average than the R33 turbos due to their ability to flow much more through their exhaust housing.
BASS OUT
On an RB25 I wouldn't go over 12psi for the street. I blew mine at 13psi.
On an RB20 1 bar seems safe.
Just thought it would be funny to quote myself.
You can run more boost with any of these turbos if you have them fitted to an RB20.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
