Hey there,
1. So for all you guys that have had the turbo die on you, was the turbo ever subjected to continuous high heat levels, i.e., drifting, track racing, or continuous on/off throttle runs through the gears in short periods of time?
2. The R34 turbo's must have a small efficiency range if they start to die around 12psi, just seems low to me, and a very quick drop off. You'd be able to verify this on a dyno by looking at inlet temps at various psi.
3. The R33 turbo on my RB20 does make a fair bit more on the dyno at 1Bar (14.7psi) as opposed to 0.8bar (12psi), but it was on different dyno's, but using the same shootout mode. Inlet temps did not skyrocket either. R33 turbo's seem to be still good at 15ish- psi..... whereas R34's seem to go off at 12.
Fixxxer
Suggestions follow;
1. Yep, going up the hill from Mooney Mooney Bridge on the F3, 4 people, boot full of wine from the Hunter = ceramic in the cat disease
2. Nope they work well from 4 psi to 12 psi, that's a big efficiency range
3. Don't confuse efficiency with durability. Also keep in mind an 8.5 to 1 compression ratio 2 litre has quite a few different characteristics from a 9 to 1 compression ratio 2.5 litre. Remember boost is simply a measure of resistance. The airflow required to make 1 bar on a RB20 is substantially less than the airflow required to make 1 bar on a RB25. Efficiency is all about airflow.
:mage: cheers :D
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
