Hey guys, well i have a 1990 R32 GTS4 and at the moment the AWD light is on in the dash, and it might go away for a bit, but it comes back. Also my ABS light is constantly on, the one that looks like (!), and no the handbrake isnt up. I have also switched around the 30AMP fuses under the bonnet and it's not them. I'm thinking it could be something to do with a faulty sensor on one of the front wheels? Any suggestions or comments as to what could be wrong?
Cheers,
Rhys
https://www.sau.com.au/forums/topic/112966-r32-gts4-awd-n-abs-lights-on/
Cheers,
Rhys
I'm pretty sure the ABS warning light is ABS. That symbol is the handbrake light, but is also a "low brake fluid" warning light.
Check the fluid level in the reservoir located RH boot for the AWD problem.
Yeah i have checked the AWD fluid level in the boot and it's full so thats not it, and i will check the brake fluid level. I was thinking it could perhaps be air in the ATESSA system as i had a new clutch installed a while back, or again the sensors which i think would be most probable. Any more suggestions as to whats wrong would be sweet.
Cheers guys
like gazza said when the 4WD light is on check the ATTESA computer in the boot and see how many times the light is flashing. All the codes are in the r32 gtr workshop manual.
ABS light is always on when 4WD light is. If the ABS light is on without the 4WD light you are probably right it could be one of the wheel speed sensors on front hubs or rear half shafts. but the ATTESA computer error will show this as well
