Brand new T04E turbo for sale
Specs:
.57 trim front wheel in
.60A/R compressor cover housing.
.64A/R rear exhaust housing
Internal gated.
T04E internals from Garret with T3 rear housing
this means bolt on quick spool for R32,R33, R34, VL TURBO, and many other cars which run the T3 rear flange.
ECU Retuning is not needed* still able to make 200+rwkw on low boost(10psi or so), but its best to have retuned ECU to suit the turbo and it can make around 250RWKW on high boost.(18+)
Brand new in box
Asking $600
Any questions please ring: 0421 795 757 or email: [email protected]
Sth East suburbs Vic. can arrange pick up or delivery.
Cheers.
https://www.sau.com.au/forums/topic/112968-brand-new-t04e-turbo/
ebay turbo, been there and learnt that lesson the hard way.
Lol yeah an ebay turbo and works fine, nothing wrong with buying off ebay just like buying somethin from someone from anywhere else, i picked this item up my self from a genuine buyer but no longer installin it in my car since i decided to sell the car. Theres nothin wrong with the turbo and its brand new, cheap and works as guaranteed from previous owner. It was in melbourne and has no problems so if ur not interested then dont bother replying, cheers.
Selling it for $550, needs to go.
i have the same turbo on my sr2o 180, ... i've had this turbo on my car for about a year now and had no problems at all, i made 227rwkw on 1 bar with FMIC, walbro pump and 3in exhaust (running a bit lean) it pretty responsive on my sr so i think it would be an great turbo for the RB25, i have no regrets buying it
good luck bro
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
