well obviously i shouldnt have posted this in forced induction but well, i wasnt sure which other one to post it in, it is electrical but its to do with ground components and stuff. any way
Basically what happens is i start the car and drive off. Steering all good, nice and light for a while, then it gets realllllllly heavy (after a random interval, usually 2-5 minutes), like as if i ran out of power steering fluid (which isnt the case) then about 30 seconds later i get the HICAS light. Then i turn the car off and on again and the steering is back to easy light steering after which it goes all heavy, then HICAS light, turn off car etc etc
Anyway its gotta be a electrical issue, right?
Can any one suggest anything, because i cant afford to take it to a mechanic and will drive it with no power steering if need be ;
https://www.sau.com.au/forums/topic/112983-hicas-hell/
The hicas controller is getting no speed signal. i assume your speedo still works as you havent mentioned it, which means either the sensor on the back of the cluster has spat it, or someone has chopped the speed sensor input to the ecu.
https://www.sau.com.au/forums/topic/112983-hicas-hell/#findComment-2082745
Yeh the speedo still works. The car was fine for quite a while (been driving it about a month no problems) until the other day it started messing up. But no speed signal = power steering not work? Just that if it was a problem with sensing speed, its unusual that it works randomly and once broken can be fixed by turning car off then on. I read somewhere that perhaps its my power levels on the battery or a alternator insufficiency. Any thoughts on that?
Also, what cluster do you mean?
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/112983-hicas-hell/#findComment-2082818
Hi mate, i got sorta the same problem but mines electrical and i know exactly whats wrong with it. when im driving without too much load on the battery eg during the day all is good and hicas light does not come on unless i got the sysem really pumping or the a/c on in which case the hicas light comes on and the steering goes jerky. At night is the worst with lights on whenever i pump the brakes the hicas light comes on n the steering goes jerky. The problem is the alternator battery power is at 11.5 volts when under load but is at 13 with nothing on so in my case its the alternater causing the hicas issue took a while to figure it out. your case may be different but i hope this helps. If you got a multimeter check your battery voltage with the car running but no lights on etc should be around 13v then turn on your lights, a/c, stereo and it drops to say 11.5 - 12 its your alternator. Also measure the negative from the earth of your car and then the negative from your battery, if theres a difference from when you measure between the + and -terminals of your battery and from when you measure from the + of your battery and the earth of your car instead of the - on your battery then its a earthing issue. Hope that helps good luck
Edited by Hui
https://www.sau.com.au/forums/topic/112983-hicas-hell/#findComment-2084235
I'm having trouble with my HICAS as well, but it's different again. Well slightly:
It all started yesterday when I changed the drivers side far right brake light. I took it for a short drive and everytime I hit the brakes the HICAS light would come on and I would loose my power steering. This is a big concern as I'm going away this Friday and I don't want problems.
After this short drive I returned home turned the car off for 5minutes and then back on and I've been on two 10minute drives since and it hasn't happened at all. The last drive I went on I put the A/C, highbeams on, pumped up the stereo, put on the demister, wiper blades and the batt didn't go below 12.5volts at all.
It's a sometimes problem that's only happened once and now it's scarying me.
Will I have full steering if it happens again?
Are there any more ideas to why it only happens when I brake?
Can it be disabled by removing a fuse? And would that disable the whole power steering or just the HICAS?
My speedo didn't drop as far as I noticed although I was going very slow and was more concerned about the light and lack of steering so maybe it was the sensor.
I wish the fault happened to a pattern, I hate these sometimes problems.
https://www.sau.com.au/forums/topic/112983-hicas-hell/#findComment-2084610
thanks hui, gotta get home try this out
Hope i dont have to spend money buying a new hicas or some crap, its definitely electrical
Took it for a drive last night, with no stereo for 15 minutes, thrashing the car, goin slow, turning alot and no probs, so ill get get my alternator checkd out at the store round the corner
https://www.sau.com.au/forums/topic/112983-hicas-hell/#findComment-2085856
  • 1 month later...
didnt want to remove hicas because, well, if i remove it and put the locking kit, without the HICAS i would have no power steering, right? (being that the hicas seems to control whether my power steering is working or not)
na the power steering works either ways.
Ive completly removed the hicas, and the steering is fine.
steve
https://www.sau.com.au/forums/topic/112983-hicas-hell/#findComment-2227814
It takes the car a good 5 minutes to realise it has no signal. Mine still throws it up occasionally if i have the car idling in the driveway for too long.
LOL. Mine just did this yesterday !! Had the car for like 6 years and this has never happened and after reading this thread, it happens..... Was on phone while it was warming up and talked for about 8-10mins and then when I went to drive away, the HICAS light came on and no power steering. Turned it off, waited about 2 mins then turned it back on again and all sweet :P
Leson learned, more drivin and less talkin !! :(
https://www.sau.com.au/forums/topic/112983-hicas-hell/#findComment-2234305
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
    • I think you might have skipped a whole vowel sounds there C.
