Just something about Mines Ecus, I know a few people who had problems with them, all R32's thou. Cars ran like crap or just died all together. Signals started to weird, eg rev counter (ecu driven) would go erractic etc. Never heard of an R33 giving problems thou, so hopefully it will last for you.
As for finds, bendi-rachet type screw driver kit, towels (even one in my door?!?, spanners, cd's, magnetic card for a Japanese Pizza place and even once in my sisters car a new jap gold credit card... 0h yeah, mine had what looked a student id card (or some id with photo) as well. Geeze they left alot of crap in mine...
Guest nismogtsx
Yeah... Ive got a Mines ECU and im not happy with it...
I am gonna actually get it out and swap it for a standard one. My fuel economy is really bad... 200kms per 60litre tank... Really Bad... Also on cold mornings it will serge in revs... This did not occur before the ecu. Also when boosting for a really long time it will boost cut, even tho i have a boost cut defender. The mines ecu overrides this signal....
Mines have one simple issue.
They are a one shot tune, which can only be re-tuned in Jap. If your car has come into the country tuned with one in it, it should be a good thing. Buy one second hand and you never know what mods the car it came off had.
With this in mind you can not really expect to do anything major with the car without getting it re-tuned in Jap.
My car came into the country with a blown ECU, I was given a Mines ECU off a wreck. The car started but ran like a dog. Too much fuel and bad cold start maps, I assumed the car it came off was highly modified. I would highly not recommend anyone buy a second hand Mines ECU, but if you have one working fine now, you will be limited to any future mods.
P.S. I have one for a 33 GTR, which I’m not going to see for the above reasons.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
