After putting my stock BOV back on i decided to check if my plugs had been fouled from it. I currently have NGK platinums and i can't tell if their dirty, and don't know how to clean them? Should i use a solution?
This pic may not help but i just need to know if their 'black' or just their normal operating colour? They've only done about 20,000km and good for 100,000km.
Pic of 1 plug
Thanks yall!
https://www.sau.com.au/forums/topic/11302-how-to-clean-plugs/
Black is just the normal operating colour... Looks like your car is maybe running pretty rich though?
I'm not sure whether you should do the same to platinums and whether they have any sort of special protective coating, but for my coppers I used some sandpaper, and then scrubbed them with a bit of metho.
Metho and a course brush is probably the safest way for platinums.
Seems to run same as before, although i did clean the coil packs too. Cylinder 1 & 2 plugs were a bit white-ish, need to get it on the dyno and fix the a/f ratio. I believe it runs rich at low revs and leans out at top. I get pinging every now and then, so i'll look into it.
Since putting on the stock BOV, noise from my pod is basically non-existant. Which is weird because why would the BOV have any effect? Its basically 1/3 as loud as it was before.
Cars running MUCH nicer with the plumback too!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
