Complete Front Mount Intercooler Kits In Stock To Suit All Major Jap Cars! Only $449!
Complete Front mount intercooler kits to suit all Major jap cars
ONLY $449 - LIMITED STOCKS
The front mount bar and plate intercooler kits are constructed entirely of high quality 6061 aluminum and the intercooler core is 100% vacuum brazed. The polished aluminum end tanks are hand TIG welded for a perfect fit. The ambient fin pitch has been adjusted to provide an optimal fin density of 15 fins/inch. This gives the intercooler excellent flow properties as well as a large cooling surface area, and the efficient Bar & Plate core takes advantage of these properties. The piping is all mandrel bent and contains only 1 weld mark throughout the whole kit. The kit includes 1x 600x 300x 76mm intercooler, polished aluminimum piping, all brackets, nuts, bolts, tripple layer silicon hoses, clamps etc.
The kits are designed to be installed DIY and are very easy to install. For installation help please email us or give us a call.
Features & Specs:
-All TIG Welded 6061 Aluminum, polished end tanks
-100% Vacuum Brazed Core
-High Efficiency Bar & Plate Construction
-3 popular Sizes available
-Inlet/Outlet: 3inch
-Low pressure drop w/ only 0.2psi at 15psi of boost
-Tested CFM: 1020 CFM
-Fin Pitch: 15 Fins/Inch
-Four Threaded Universal Mounting Points
FREIGHT: (all items are sent out by registered post with full insurance)
VIC: $30
SA/NSW: $45
QLD: $50
WA/NT: $70
IN STOCK NOW READY TO BE SENT OUT OR PICKED UP!!!
To order please send me a PM or send an email to [email protected]
mine hasnt arrived yet :P
Please send me a PM with your order details.
To get from here to Austrlia wide can take up to 6 working days.
cheers,
Greg
hey mate,
do you have a pic showing in the inlet/outlet? cheers,
also do you only sell bar and plate, or also tube and fin?
-JD
Hi, you can see more pictures of the intercoolers on our website here: http://www.gktech.com.au/products/?id=57
We only have the bar and plates at this stage.
cheers,
Greg :P
I'll just wait. I know you went too china. Not trying to cause any trouble.
I am still in China but things are running as per usual and all orders have been sent out within 24 hours of receiving payment, I don't know which day your kit was sent out because I don't know who you are.. If you could send me your information I can check it for you on our order system.
cheers,
Greg
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
