Hey guys, just recently I've developed this high pitched whining sound that seems to be coming from either the front or rear wheel on the drivers side. Anyone got any ideas as to what this could be or any way I could diagnose it?
Could be wheel bearing, take each wheel off and spin the hub, you should be able to tell if its stuffed if it doesnt spin free. Out of gear and handbrake off for the rear of course.
Hey dude, sorry to hear about the probs with ur car. i am guessing either a faulty wheel bearing( it will be easy to tell if the wheel doesnt spin freely and feels sloppy when you try and shake it) or one of your brake pads has been overheated or is worn out and is touching the rotor occasionally, causing the noise. Does the noise happen after you have braked or when you are driving along??
It seems to happen when I'm driving along, at times it will be silent then out of nowhere it comes again. My brake pads have lots of meat left, so I doubt it's them, though I can't be 100% certain. Guess I should just jack the sucker up and try eh? I'm guessing most likely it's the wheel bearing but without lifting up the car I can't know for certain
R33 Stealth, DEFINATELY not a belt sound...
MaTBoY, funny you should say that, I was gonna put in my original post that I've already ruled out the missus as a possible source :devil:
Abo Bob, I bled the brakes maybe 5-6 weeks ago
It would be the wheel bearing Thats how mine is, It comes and goes turn a corner it could go away, But when me and mates looked at the wheels they dont spin freely.
Does anybody know how to access them and change them, I dont really want to pay some fool $400 to do it and find I could have done it in 4 hours.
I need a Diag or something of the wheel assembley
7yphon, I came across this and was going to follow it after confirmation of my problem, beleive it come be some use to you...
http://www.skylinesaustralia.com/forums/in...0entry2082203
I have the same sounds and I'm not sure what it is really...myabe it is the wheel bearing. But form my experience when the bearing is gone it makes a more low pitched grinding noise...I will take off the wheel and have a go...
  • 1 year later...
on the money,
depending on how bent they are you would probably want to check.
you might have crap loads of meat on the pads or you might not, either way to get rid of hte noise you are going to have to get at the pads anyways to check.
its a piece of piss to pull the bloody pads out and bend the indicators to where they should be if you have heaps of meat left (keeping in mind evenish wear etc).
I can tell you I've had this problem a couple of times with my rather dust inducing ultimates. half way through life theres always a pad that nneeds the guide to be bent.. just got bent in somewhere along the way and i forgot to check and bend to the appropriate spot.. no biggy. take the half hr to check all 4.. re-bleed brakes for some good pedal feel and top up the resevoir... walla...
so simple i could train a monkey to do it >:wave:
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
