Edgeworth To Walka Water Works Cruise Easter Monday 17/4
ULOOOK
 Share
Ok people, we went for a drive up there today and turned back just after cessnock cause the road got too bad. The new destination is Walka Water Works(5 mins from maitland city centre) its a lovely spot with bbqs, tables and chairs room to kick a ball around etc. Entry is $3 to the park. *Details in 1st post*
  • Replies 45
Posted Images
were in...
we'll be in the otha halfs car, mine doesn't get driven much anymore.
how many of us are definates?
so is it byo food and drinks or is that supplied at a cost?
we can meet you guys at the servo at the end of the freeway if your going to re-group.
let us know..
OK 7 Definates 2 maybes.
Byo everything, nothing is supplied. There are eleco bbqs up there. Dont forget $3 for entry to the park.
Mum's Taxi - We will meet you guys out the front of the caltex off weakleys drive, i think its called yangan drive. At about 11.15 if you like.
Im not sure if my frontbar will stay on at high speeds, so im still undecided...
Just come man, we will stop and help you pick up the pieces :bunny:
Hey guys, im going to have to say - count me out- at the last minute! Im sorry! :)
But i will be keen to meet in town if you guys do drive back, just give me a msg on 0417268091 when you get in there.
Cheers, and have a great first half of the day.
ok this should be good
no probs we'll be at the caltex at 11
we should have another car with us as well
so will we all be cruisin bak into town together afterwards?
No probs, we might head into town after, see what happens.
Ill let you know when we are leaving dave.
yeah man we seen that... we thought you were gone for sure.... at least it was only ride hight.....talk about bad luck...you barely drive your car as it is and the one time u bring it out u get pinned.. that really shits me!!!
Ahhh Adam, bummer man!!!!
At least your defect wasnt as big as my defect list after the last cruise!!!
But to cheer you up i got heaps of photos of your car and PM's them to you :P
Thanks for orgainsing the event Josh+Krystle (and for the snag + eggs too!!)
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
