Ok people, we went for a drive up there today and turned back just after cessnock cause the road got too bad. The new destination is Walka Water Works(5 mins from maitland city centre) its a lovely spot with bbqs, tables and chairs room to kick a ball around etc. Entry is $3 to the park. *Details in 1st post*
  • Replies 45
Posted Images
were in...
we'll be in the otha halfs car, mine doesn't get driven much anymore.
how many of us are definates?
so is it byo food and drinks or is that supplied at a cost?
we can meet you guys at the servo at the end of the freeway if your going to re-group.
let us know..
OK 7 Definates 2 maybes.
Byo everything, nothing is supplied. There are eleco bbqs up there. Dont forget $3 for entry to the park.
Mum's Taxi - We will meet you guys out the front of the caltex off weakleys drive, i think its called yangan drive. At about 11.15 if you like.
Im not sure if my frontbar will stay on at high speeds, so im still undecided...
Just come man, we will stop and help you pick up the pieces :bunny:
ok this should be good
no probs we'll be at the caltex at 11
we should have another car with us as well
so will we all be cruisin bak into town together afterwards?
Hey guys, im going to have to say - count me out- at the last minute! Im sorry! :)
But i will be keen to meet in town if you guys do drive back, just give me a msg on 0417268091 when you get in there.
Cheers, and have a great first half of the day.
No probs, we might head into town after, see what happens.
Ill let you know when we are leaving dave.
Thanks to everyone who come, it was a nice day. It was good to meet some new people.
If anyone got any good pics could they please send them to me at [email protected]
Thanks
Josh and Krystle
Edited by ULOOOK
yeah man we seen that... we thought you were gone for sure.... at least it was only ride hight.....talk about bad luck...you barely drive your car as it is and the one time u bring it out u get pinned.. that really shits me!!!
while we were still in town we saw the same cop pull ova quite a few skylines.
so we all decided it was best to leave when we did
I think it was a pick on skyline day
Ahhh Adam, bummer man!!!!
At least your defect wasnt as big as my defect list after the last cruise!!!
But to cheer you up i got heaps of photos of your car and PM's them to you :P
Thanks for orgainsing the event Josh+Krystle (and for the snag + eggs too!!)
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
