This turbo is a monster with a 1.15 A/R exhaust, but has anyone done it and what lag can be expected? Boost to kick in at 5k or a bit better than that?
Advice appreciated.
FMIC
Haltech
Stock internals
3" full exhaust etc.
would only be running 1 bar.
https://www.sau.com.au/forums/topic/113094-gt42-on-rb25det/
I bolted on a HKS T51R Kai BB for shits and giggles to a stock RB25 longblock. Had a Greddy plenum/115mm intercooler/PowerFC.... was a rocketship i tell ya! Had to flatchange gears to get some boost into the system, made next to no boost in 1st gear. Only ran 9psi, was a bit timid with boost at the time. Had to bump up the rev limit on the dyno to 8500, when it hit boost at 7k it fried the tyres.
Oh, made power for alot more than 2 minutes. Took it off out of frustration (and had another turbo to try out). Even tried out circuit racing at Eastern Creek with it, Roy and I couldn't stop laughing at it (well, until it fouled the plugs and nearly had to be towed off).
Visual appeal was at a maximum though.
https://www.sau.com.au/forums/topic/113094-gt42-on-rb25det/#findComment-2085457
http://i69.photobucket.com/albums/i70/tjomi/DSC01157.jpg
Was going for the 42, but I chickened out because it scared me unpacking it.
Went for littlebrother GT40, and that one even looks too big.
The little one is a 600hp Precision turbo!
I`ll give the GT40 a try.750hp rating. Wiseco/Crower internals.
https://www.sau.com.au/forums/topic/113094-gt42-on-rb25det/#findComment-2085602
It was only by chance that I found one so I figured I would ask.
I really want a GT30/40, GT35/40 or a HKS 3037S something equivalent which is proven on the RB25's.
But thanks for the input, like I said appreciated.
https://www.sau.com.au/forums/topic/113094-gt42-on-rb25det/#findComment-2085647
It wasn't a lag monster, it was a Skyline built for cruising. You could call it a Skying.... or a Cruiseliner? heheh
Those guys that were with me the night you gave me a lift to the Swans game still pull their d1cks over how it went, and more imprtantly how it sdounded when it spooled and hit boost.
It was so cool, the sound alone was worth every second you had to wait to boost.
https://www.sau.com.au/forums/topic/113094-gt42-on-rb25det/#findComment-2086187
Advice appreciated.
FMIC
Haltech
Stock internals
I think its sufficient to say that an 800Hp turbo is a long way out of place on an RB25 , it would be extreme on an RB26 and laggy on a street driven RB30DET .
If you go this way and I strongly advise you don't , use the HKS version which is called T51R as it uses a smaller trim turbine than the Garrett marketed GT42R ie 76T vs 84T .
Very very laggy , very expensive and very likely to destroy your RB25 . Why bother .
Cheers A .
https://www.sau.com.au/forums/topic/113094-gt42-on-rb25det/#findComment-2086314
If it were me on a std RB25DET I would do the HKS GT3037 in 52 comp trim or ask GCG if they can make a similar combination up for you . A lot of people find the GT30R (the real one which is same cartridge as GT3037 56T) is laggy and you have to push it to get good squirt which is a pain in a road car . Small AR turbine housings only make them surge so that 52T compressor is a must and makes 40lbs airflow in .50AR TO4E cover so 400 should be no prob .
A bit OT but we need Garrett Japan to make GT30 and GT35 turbines in smaller trims than 84 , the current GT40R uses a 78T and the High Kost Spec GT42R (T51R) a 76T turbine .
Cheers A .
https://www.sau.com.au/forums/topic/113094-gt42-on-rb25det/#findComment-2087218
if it's any use as a comparison, i have a GT40 with a 1.34 A/R rear housing on my RB30 DET. standard cams, custom plenum and exhaust manifold.
1st gear: lucky to see 4psi of boost at 6000rpm. full traction.
2nd gear: 10psi around 4800rpm (hard to tell) lots of tyre frying. goes from 70km/h to 130km/h in the space of about 1 second. this gear feels roughly three times as fast as first did.
3rd gear: 10psi at 4000rpm. traction is borderline. very fast gear up top past 150km/h.
4th gear: load it up and you'll have 10psi at 3500. by then you're doing close to the sound barrier anyway so you better stop quick.
on a 25 even the GT40 with smallest rear would be stupid, let alone the one i have.
p.s. makes great noises though, this turbo!
https://www.sau.com.au/forums/topic/113094-gt42-on-rb25det/#findComment-2089602
Precision makes smaller exhausthousings for the GT40. This one is A/R 0.81 with 69mm outlet.
They call this turbo GT4067R. Rollerbearing core. 750hp rating. 1.5bar/22psi at 4800-5000 rpm with some good cams. I`ll post my dynopaper when done building/ mapping.
https://www.sau.com.au/forums/topic/113094-gt42-on-rb25det/#findComment-2089704
Guest
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
