Hey guys another silly question is there two different types of vg30dett one being a DET not TT also if there is are the turbs different one being steel wheeled i got told i was buying a steel wheeled vg30DET turb but not sure how to tell wat is wat if its steel wheeled wats the safe boost level ADRNLN Billy got this turb for me so hoping its all good he said it good for 18psi but i only want 14 to 15 psi will it cope..... :O
https://www.sau.com.au/forums/topic/113111-vg30-turb/
if its on your car already and running ...... its pretty easy to work out if its a DET version.. she wont make full boost to around 4000rpm
laggy sons of bitches on the 20s..... but great fun i reckon.
some where steel wheeled.. in the earlier Leopards and 300zx's .... most of the later ones are ceramic rear..... 15psi would be safe amount to run without leaning too hard on the motor or the turbo if either of the 2 arent in 100% working condition.
OP6 on teh rear housing is what u gotta spot before u cough up bills for turbo.
mine cost me 150bucks....lol few months of boost .. freed it up and it stopped making shitty bearing noises..... but gives me the impression its bush not ball bearing'd
Matt
https://www.sau.com.au/forums/topic/113111-vg30-turb/#findComment-2085529
Thanks if thats the case im pretty sure its the DET version it doesn't start spooling till round 3800 full boost at 4600 got told it was because the cooler and piping i was running plus the timing is out i think. 600/400/100 i think pretty big all the same with 3'' piping on it and only 7psi. Will timing make the turb come in later
https://www.sau.com.au/forums/topic/113111-vg30-turb/#findComment-2085543
Matt
I agree Ithink some were steel wheeled. Also the Vg30det's came from the factory with forged internals. So obviously they were meant to handle more boost from the factory.
https://www.sau.com.au/forums/topic/113111-vg30-turb/#findComment-2085674
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
