HI ALL
I HAVE THESE PARTS FOR SALE
1X R33 GTST SERIES 1 GENUINE M-SPEC PLASTIC FRONT BAR IN WHITE NO DAMAGE OR MARKS $500
2X R33 FRONT TURBO CALLIPERS 30MM AND 296MM ROTORS IN ECELLENT CONDITION THE LOT $400
2X R33 REAR TAIL LIGHTS COMPLETE LIKE NEW PAIR $280
1X R33 GTST STANDARD TURBO RB25 SERIES 1 ONLY 56000KMS NO SHAFT PLAY $500
1X R33 COUPE MASTER DOOR/WINDOW SWITCH $200
1X Q45 90MM BIG AIR FLOW METER $200
2X R33 REAR TURBO VENTILATED ROTORS PAIR $150
1X STANDARD BLOW OFF VALVE PLUM BACK $40
1X STANDARD AIR BOX WITH SNORKLE LIKE NEW $200
1X ENGINE FAN (NO VISCUS) VERY CLEAN WHITE LIKE NEW GOOD FOR SHOW CAR $150
1X R33 COUPE REAR PARCEL SHELF GOOD CONDITION $50
1X FRONT POWER STEERING RACK COMPLETE WITH TIE ROD ENDS $200
2X DOOR TRIMS LEFT AND RIGHT GOOD CONDITION $100 EACH
4X STANDARD SUSPENSION SPRINGS FOR FRONT AND BACK GTST $100 THE LOT
2X SERIES 1 BAR INDICATORS PAIR $80
ALL NEGOTIOABLE OPEN TO OFFERS AND WILL POST (AT COST)
CALL ON 0419777522 OR PM
Edited by Hooman
  • 4 weeks later...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
