both cars that i own have fog lights, ive driven through fog and dont notice how they can help??
but my question is... do you have the head lights off and only the fog lights on when driving through fog??
maybe a simple and general knowledge question but im just after a quick answer..??
thanks
https://www.sau.com.au/forums/topic/113127-how-to-use-fog-lights/
They're not to help you, they are to make it easier for you to be seen by other drivers.
You use them as well as your dipped headlights, you don't use full/main beams in fog, as the light just reflects off the fog and blinds you.
Edited by PlasticStan
Use fog lights only. They are mounted low so they shine under the fog. Headlamps - hi or lo beam - will reflect back off the fog.
this is what i thought because normal or high beams reflect. on coming drivers will see wether you have high beams or not because theyll see a glare of light, but i guess the foglights would still "look" round or square...
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
