just wanted to know if anybody has replaced the guages in the centre console and if so what breeds did they use and was it in the original cluster? or did you have to butcher it to fit them in?
i have sen some blitz guages that are in a single din carrier woudl these be usable?
also was just looking on nengun and saw some DEFI guages that are designed for fitting into a single din. but cant really make out what the guages are meant to indicate as the pic doesnt show real clear,as well as the description is not real 'descriptive'
if any one could tell me would be great.
Edited by oxford1327
https://www.sau.com.au/forums/topic/113158-replacing-centre-console-guages/
This is what I'm looking to do in the (hopefully not-too-distant) future. The gauges you'd want (whether they're Defi, Apexi, or whatever) are ~52mm in size, and there are DIN gauge holders available for them from various sources.
Not too sure whether they'll fit in the gauge holder of your Stagea in place of the standard gauges, but I suppose if you can get the standard unit out and take it into a shop then you may have a better chance of finding that out.
The Defi DIN gauge you've seen on Nengun has three set gauges (you can't choose which gauges it comes with), and you can get more info here: http://www.defi-shop.com/product/din/din_top.html
There are cheaper Defi-style gauges around, with either the black face or a mirror face, but if you're choosing a boost gauge to add to your cluster, then they're mostly all mechanical gauges, not electronic ones. JustJap (http://www.justjap.com) and AutoBarn are two places that have the cheaper ones available, and JustJap also has a DIN-sized holder for them.
Hope that helps...
Nick
awesome thanks for that i have been surfin around lookin at heaps of different sites lookin at all sorts of things and have since found a few different styles of 'pods' that fit in a din slot but would ideally like to replace the existing ones and keep the same carrier for looks etc. but am yet to try and take the carrier out of the dash to see whats goin on behind there.
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
