Some nankangs which I beleive helped things along and ypur write you dont have to be young and dumb you can be old......eer too but its road conditions you have to be most carful off. Thanks for the support guys .popped some ribs cartlige which will take a while too heal then take some time and build a better one next time . Dont think I'll paint it black though shows the scratches in the pic's to much ,wot you recon :(
cheers Peter
  • Replies 51
As topic states I walked away from this last friday night
So if anyone comes across an R32 shell let me know time to rebuild again
Cheers Peter
Faaark, dude I sugest getting a cage. Good your ok though.
glad your not too hurts
reality check for the kiddies out there looks like and impact speed of around 30-40 km/h
any faster and you would have been in hospital for a good deal of time and you lucky whatever you hit had a good diameter which helps in a lower speed impact
fatz
Dude ! Glad your ok. Went through something similar about a month ago sitting at an intersection waiting to turn right was hit head on by a Porsch running a red trying to avoid hitting a van doing a u turn at the lights ! Ambo, intesive care the works ! Concrete medium strip got him airbourne on impact, spun 180 and smashed into the back of my line above the rear right wheel ! So I know what youve gone through and as long as your ok the rest dont mean squat !
DAMN
you were very lucky to walk away from that without being hurt champ.
Glad your ok and good luck with the new build up :domokun:
I have a shell with a few goodies but crook motor in Tassie if your interested >_<
Cheers GMB
damn !!!!!!!!!!!
that is a pretty bad accident.....I think you and I both have used one of our nine lives.
I had an accident slightly worse than that a few years back....XF falcon rammed by corolla from behind at 80km/h + and the car flipped vertically and landed on a fence....it was a corolla sedan csi after the accident it looked like a chop top hatchback....
Were you shaking a bit when you got out of the car ??
I know I was....
Anyways at least your ok !!!!
Edited by shonen
Good to read your not too badly banged up. (it good to have a war story, but not have to tell it from a wheel chair) :bunny:
Bugger. Could well of been the country's quickest std RB20...what tyres were you running again? Your thing was half the reason i didnt bother running mine as i knew you were about to put down the numbers and fly the flag
Hope your recovery goes well....and a R32 shell comes your way soon!
Roy engine still running fine not even a water leak after that so when i get a new shell and slip in the running gear I'll try flying that flag again , and silver thanks man
Cheers Peter
P.S I might paint the next one red there suppose to be faster arnt they
wow...
can I ask where you're located to have frost on the road? I've never seen this in sydney..
also, before you ditch the car, please sell me the vents and other internal bits that you won't use in your next car.
glad you came out of it with a little rib pain only.
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
