Job: Rubber and Hose Man (Purple Pig)
Car: 1990 R31 Silhouette GTS 2 (Ex Cop Car) - Build number 1 0f 7.
Engine: RB30E + T
Mods: VL highflow turbo, vlt exhaust manifold, vlt injectors, remapped ecu to vlt specs, fmic, 3" exhaust
Gearbox: R32 gtst
Suspension: stock GTS2 Bilstein shocks.
Wheels: Stock GTS2 Wheels.
Power: Made a max of 164rwkw on 12psi. Will be fixing that problem very soon......
Edited by Young GT-R
  • 1 month later...
  • Replies 117
OCCUPATION: Comms Tech
CAR: R32 GTST
Mods:
Front Mount IC
T70r Turbo W/Top mount extractors
DENSO 500cc Injectors (RX7 Series 5)
Custom Pipe work
Self chipped ECU
17" RJR Circuit Rims (white)
Boost Controller
Still a WIP but is coming together
  • 1 month later...
Occupation: Student
Car: 1994 R33 GTST (my new baby! :D
Mods:
* Hi flowed/strenthed turbo with t3/t4 internals.
* Replaced stock ceramic wheel in turbo to a stronger steel wheel.
* Hybrid FMIC
* Xforce 3" exhaust from turbo back with hi flow r34 catalitic convertor.
* Pod Air Filter
+ more to come - when i get the yen :P
currently misfiring @ 4500-5000rpm atm. I hear covering the coilpacks works a treat so i'll try that this w/e, if
anyone wants to give me a hand you're welcome hohoho :D
p.s excuse the nsw plates, haven't taken them off yet.
Edited by magnose
  • 1 month later...
Job: Web Coordinator - University of Tas
Car: 2001 Series II Bayside Blue R34 GT-T (not a common 98)
Mods n stuff:
Not alot, Apexi Power Intake, Blitz BOV, 3" Turbo Back stainless exhaust with a 7" barrel and a 5" Tip, HKS TT, IRIWAY racing plugs, Nissan Sports kit, Jun Eyelids (yet to be installed), AVCR (yet to be installed), usual MOMO gear
Other:
Alpine D310E DVD/TV, Type X Splits, Stinger 0G kit and to go in is another pair of type x splits, 2 x type X 12" subs, 2x 1 channel 1000w PDX amps, 1x 4channel PDX amp, 1 x Cap....
Had to pick small res images
Edited by Edstrodamous
Job: Glazier/glass cutter
Car: Blue R32 GTR Skyline
Mods: Just had the engine rebuilt and currently running it in. Got some hks turbos in it not sure on what type tho. Will be installing apexi power fc and a new boost controller shortly should get along pretty nicely :)
Edited by matta21
Name: Maciek AKA Wog AKA WogsRus
Location: Hobart/Launceston (do a fair bit of traveling)
Job: Mechanical Engineer for SEMF
Car: 1995 R33 GTST Series 1.5 TYPE M ( Series 2 running gear, engine, ecu, interior, rear body shell ect, with series 1 front)
Mods: Only had the car 2 months so limited as for now.
Engine: RB25DET, FPR, Walbro GSS342 Fuel Pump, HKS intake and Pod, $22 Bost controller, CRD 600x300x100 FMIC, Apexi SAFC II, Full 3' exhaust with dump and highflow cat, new O2 sensor, New ECU temp sensor. (not in but a full Wasted spark ignition system in the works)
Exterior: All Type M body kit with optional Type M suspention, Sunroof, Speedy Spyder Gold Rims with MAXXIS MA-V1 tyres.
Drive: Standard gearbox with some sorght of heavy duty clutch, not sure what, was already in the car.
Interior: Sparco Boost guage, RAZO turbo timer, pedals and gearknob, SAFC II.
FURTURE: I have to fix my beloved bike and sell her to raise seme funds, and then go for a full new turbo setup, PFC ect, My long term goal is to have a 500Hp street driven Skyline. I know i can dream. One day.
For pics see
http://www.skylinesaustralia.com/forums/in...howtopic=132207
and
http://www.skylinesaustralia.com/forums/in...howtopic=135918
Edited by WogsRus
  • 3 weeks later...
real name - Ricko.
from - Launceston
car - 89 r31 gts2 skyline
engine - rb30e+t
mods - 3" exhurst dump back, mirotech lt8s, custom front feed plenum, gts2 cam, garrett t3/4, vlt injectors. 300x600 nispro tube and fin intercooler.
car was dyno tuned by brad sherriff at chris golgrave in lonnie.
vlt injectors are at around 92% duty cycle. ( only just safe )
car made max power at 4950 rpm, 206.7 rwkw - 430 nm of torque at the wheels.
Name Stuart
Location Hobart
Job Network support
Car 89 4 door R32
mods
Fmic
Tein HR coilovers
Hicas Lock bar
White buddy club P1s
2 way LSD
greddy profec b spec 2
greddy T/T
bosch 040
Xforce 3inch turbo back exhaust
elevo wheel
exedy clutch
R32 GTR seats
drift button
apexi power intake
Strut brace
D-project castor rods
D-project tie rods
D-project tie rod ends
D-project subframe bushes
D-project lower arm brace
Edited by TazzS13
  • 4 weeks later...
Job: Fish farm manager
Car: R33 S1 4door
Mods: just a few for the moment, Highflowed turbo(by GCG) FMIC from croydon 600x300x100, 3in exhaust, split dump pipe, Jamex coilovers (stiff as sh!t that has dried for a year), K&N airpod, lowered, Boostgauge.
Pics: look here: http://www.skylinesaustralia.com/forums/in...=133826&hl=
Job: Insurance rep
Car: 1996 R33 GTS-T series II
Engine: RB25DET
Mods: Pod, 3 inch kakimoto exhaust, High flowed turbo, Hybrid FMIC, boost controller, turbo timer, all the usual stuff
Gearbox: Standard
Suspension: ISC adjustable Coilovers front and rear
Wheels: dunno brand 18" (265's on back)
Power: Last week dyno'd at 201.1rwkw at 9psi
And tomorrow I will have my second r33:
1993 R33 GTS-T Series I
Engine Internals Consist Of:
- Aries Forged Pistons,Aries Molly Piston Rings & Bearings, Shock Pein RB25 Conrods, Crank X-Rayed, Polished & Balanced, Head Has Stainless Valves 30mm Exhaust 34.5mm Inlet, Three Angled, Cut Valve Seats, Ported Polished, Flow Tested & Manifold Matched For Optimum Flow
Engine Externals & Bay:
- Detailed In Blue Print, 6" Cold Air Induction System, Simota Heat Shielded POD Filter , Straight Pipe From POD To Turbo (Non Restrictive), Custom Turbo Set Up High Flowed T3 Front VG30 Rear Housing, Boosting up to 19Psi, RB20 Waste Gate Actuator, Monster Hybrid FMIC & Piping, Polished Throttle Body, Turbosmart Super Sonic BOV , 3" Mandrel exhaust From Turbo, 3" High Flow Cat Into 4" Apexi Cannon, Exedy Racing Clutch & Pressure plate, Lightened & Balanced Fly Wheel
Exterior:
- 400r Front & Rear Body Kit With GTR Sides & Spoiler, 17" Import Rims With New Rubber
  • 1 month later...
JOB: Artificial sandstone maker (Thunderstones)
CAR: 1994 R33 GTS-T
MODS: None, besides a turbosmart dualport BOV and a VS style body kit currently on its way from nsw.
Havent got pics as yet cuz i dont have anything to take em with, lol.
  • 4 weeks later...
Name:
Job: Installation technician at Autobarn
Car: 1993 R33 GTS-t
Mods: Autotechnica 600x300x76 front mount and piping, Turbosmart supersonic BOV, removed all aircon, carbon canister etc, Turbosmart boost controller, Drift seperated dump/wastgate pipe, Drift 3" catback exhaust. tein HR coilovers, Work rims 275/35/18 back and 245/35/18 front. (about to be power coated white), Trust Body Kit, Gtr rear wing, Resprayed in Bayside blue. Gtr seats and interior panels, retrimmed roof and gear boot/hand brake in blue vinel, painted all hard plastics inside in Bayside Blue. Clarion dual din CD/sd card with built in hard drive, rockford fosgate splits front and rear, pioneer subs, 9.2in flip down TV screen, slimline PS2 in glovebox, and HID Xenon headlights.
Waiting to go on is, Greddy knock off plenum, stainless low mount manifold, heatwrap for manifold and exhaust, Daiken Lightweight Flywheel.
Best i have pulled at the drags was a 14.3
Edited by guesty
  • 3 weeks later...
  • 3 weeks later...
Job: Mechanic / auto elec / workshop manager
Car: 89' R32 GTR
Mods: GT2860R - 5's
HKS pods
3inch into cat 3.5inch back to HKS super dragger
N1 oil pump
N1 water pump
JUN light weight pulley
Mines ECU
Oil catch can
Nizmo dash
PBR heavy duty clutch
19' HP design rims
Match ported exhaust manifolds
After market fuel rail
Different injectors (not sure how big)
Some Jap brand coil overs?
Custom "GTR32" plates
Air conditioning, power windows, WTF!!
Future mods : Wolf 3d v5, fuel pump, Respray (some cum junkie tried to break in and scratched the boot!) Tein coil overs - then I'll be happy!! :sorcerer:
NAME- brad
LOCATION- kingston
JOB- app greenkeeper at northwest bay golf club, part time houn caltex servo
CAR- 89 r32gtst
MODS- front strutbrace, 3in front/pump pipe, 3in ss drift cat back to 4in tip,
ARC fmic, HKS pod fillter, exedy tuff sport clutch, 12in sub and amps,
bar pressure gauge, 4in tacho with shift light, imbolisler
  • 1 month later...
NAME- Josh
LOCATION- hobart
JOB- Carpet
CAR- 1983 dr30 skyline
MODS- cusco coilovers, r32 rotors and calipers on front, wantanabe rs8's, stripped interior, fixed back seat, harness, painted floor, aluminium door trims and fire break panel at rear, fuel cell, bosch 910 fuel pump, currently under going and engine conversion from the old fj20 to a rb25, rb25 has adjustable cam gears, cometic head gasket, new timing belt, 550cc injectors, ext gate manifold, hks ext gate, T70 ( :/ just for now) excedy clucth and will have a front facing plenum as i don't have the clearence to run the usual plenumn as it would hit my brake cylinder.
Edited by j_ priseman
Ɨ
Ɨ
