Could someone confirm the effects of rear toe either, toe in, 0 or toe out, especially for R33 Skyline GTS-Ts.
Pretty sure I understand front toe effects but still not 100% sure what happens with the rear. Is it simply the reverse of the front, ie. front toe in induces understeer due to less overall grip, so rear toe in induces oversteer becuase of the same reasons?
SK has recommended 2mm toe in for the rear end of my car (as part of other recommendations) to help dial out rear oversteer which I'm still trying to get my head around.
Cheers!
Edited by Freebaggin
https://www.sau.com.au/forums/topic/113257-rear-toe/
Toe out can be referred to as an "ubstabilising" setting
Toe in is considered a "stabilising" setting
So if you want more response, go for toe out
If, on the othe hand, you want more stability, go for toe in
Hence toe out on the front makes that end of the car more lively, reponsive to inputs such as steering. Toe out is on the front is good for improving the initial turn in to a corner for example.
Conversely toe in on the rear makes that end of the car more stable, less reponsive to inputs such as power application. Toe in is good for decreasing the power oversteer on corner exit for example.
As always you get nothing for nothing.
If you run toe in on the rear to help decrease the power oversteer the side effect is more reluctance to run into the corner. The rear end remains stable rather than move out to assist the turn.
So the common RWD Skyline setting is toe in on the rear and toe out on the front.
That should be enough to get you thinking
:) cheers :)
Edited by Sydneykid
https://www.sau.com.au/forums/topic/113257-rear-toe/#findComment-2088271
Cheers!
The key to understaning rear toe effects is to understand how a tyre generate cornering grip. Put simply, when turning a corner there will always be a difference between the direction the tyre is pointing and the direction in which it is headed. This is known as the slip angle. Up to the grip limit of the tyre the higher the slip angle the higher the cornering grip. The amount of grip the tyre generates is also proportional to the load on the tyre, ie vertical force acting on it. The more downforce on the tyre the more grip it can generate.
If you think about the rear suspension, when travelling in a straight line the two rear tyres, by courtesy of the toe in, are both generating a cornering force - but they are cancelling each other out. When one rear tyre is loaded more than the other (ie the outside wheel when cornering) the toe in/out on this wheel becomes the point of interest and the inside wheel can largely be ignored.
If you put toe in on the rear suspension (ie front of the wheel pointing in)you are, when cornering, essentially doing the same thing to the rear of the car as turning the steering wheel does to the front. This makes the car, in a relative sense, understeer a little more than it might otherwise.
If you put toe out (ie front of the wheel pointing out) you will have the effect of adding a little more oversteer to the car when cornering.
The point to be a little careful of is that when you go over a bump in the road and this only hits one wheel - too much toe in will make the car steer from the rear. Not much fun.
https://www.sau.com.au/forums/topic/113257-rear-toe/#findComment-2088303
  • 1 month later...
So that's 2mm TOTAL toe in on the rear or 2mm each for a total of 4mm?
That’s 2 mm each side, be specific with the aligner. Some of the dumber ones think the rear is the same as the front and they can set it at 4 mm total toe in.
:D cheers :D
https://www.sau.com.au/forums/topic/113257-rear-toe/#findComment-2216245
the amount of wear would come down to how much camber vs toe. my skyline has been lowered and i was told that instead of getting a camber kit, get the toe matched to the camber to make the tyres wear evenly.
the more toe in you have, the more outside wear you get and more toe out the more inside wear you get.
so if you have lots of camber and lots of toe out you would get extreme inside wear.
https://www.sau.com.au/forums/topic/113257-rear-toe/#findComment-2219317
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
