My GTR has been shitting itself lately.
dropping revs to the point of completely stalling in the space of about 3 seconds....
stalling for no reason at idle.... accelerator being non responsive... slugging, lacking power.
could this be my problem?
cheers
  • 2 months later...
just to let everyone know, i just done this tutorial on my car as it was almost un-driveable and it has fixed it better then when i first got the car back 5 years ago.
My issues were:
1. Stalling when slowing down
2. Miss-fire every second or two
3. Cant rev over 3000 without making lots of backfire and smoke out the exhaust
4. And every now and then entering limp home mode when first starting the car.
I suggest everyone should try this if they have 2 or more of these symptoms
If this didnt fix the car then i was going to get a Auto-Sparky to look at it.
  • 4 weeks later...
I did this back when I had my GT-R, it got me out of trouble for a few weeks while I sourced a pair of AFM's, I bought a pair as they were matched and funnily enough the other stocker died not much later so I was glad I had the pair.
This works but for how long comes down to many other factors.
I just bought a 33 GTR and it was doing the whole running rough and stalling and hunts for idle, have taken off AFM's and re soldered them as a couple of the pins were not making a solid connection, put them back on and reset the ECU and it made no difference. I know its the AFM's as i have hooked up the diagnostic console and the only error code that popped up was AFM's.... i am a little puzzled and have checked all visible wiring for the afm's aswell as the plugs and all seem fine :P
Mine didn't last long soldered, best to swap in some new or second handers.
If you're confident it's the problem then the soldering is not worth the headache in the long run. Some may be more damaged that others and be more successfully repaired than others too.
good luck.
  • 2 months later...
  • 3 weeks later...
  • 3 months later...
I just bought a 33 GTR and it was doing the whole running rough and stalling and hunts for idle, have taken off AFM's and re soldered them as a couple of the pins were not making a solid connection, put them back on and reset the ECU and it made no difference. I know its the AFM's as i have hooked up the diagnostic console and the only error code that popped up was AFM's.... i am a little puzzled and have checked all visible wiring for the afm's aswell as the plugs and all seem fine :)
Clean the element. Use CRC contact Cleaner. The actual AFm sensor itself.
would you suggest trying this for mine. The problem with my car is ever since i noticed 1 of the AFM voltages being very low compared to the other one its been popping and backfiring alot. So i thought i might try and give them both a clean.
  • 2 months later...
I bought my car 4 weeks ago and it was doing the same thing:
-dropping revs and stalling when slowing down
-dropping revs and threatening to stall with aircon on
-stalling/misfiring on acceleration
(all in a matter of within 3 days).
Sent it to the mechanic took them 3 days to work out what was wrong, they cleaned the AFMs and the car seems completely different now, it actually goes on boost. Will have a look at the contacts if this problem comes up again.
  • 6 months later...
hey guys, this is great info!! I re- soldered my connections even though they looked ok, but also found alot of corrosion on the printed circuit board under the gold coverplate. Either way car's fixed idles smoother, don't cut out and feels like its picked up a handfull of kw!! win win!
  • 7 months later...
Bumping for usefulness.
I was about to chuck a thread up saying how I did this as a fix but found this first. VG30 in Maxima being pain in the ass on all types of driving, but very very intermittent. Cleaned AFM and contact cleaned corrosion off one of the contact pins to no avail.
Not knowing the internals of the AFM I took out them 4 screws and lightly tugged on the socket, and like you said it came out surprisingly easy.
Now, knowing it's broken anyways, I pried the top off and saw the 4 pins were all intact, resoldered the joints and it's been running fine ever since. Lots of money saved. Remember to reseal the join on the lid with some gasket goo.
+1.
  • 6 months later...
Hey,
Just reading through this now, I think I have the same problem as you guys, but I think My AFM PLUG is also loose with the wiring..
any of you guys live in West Melbourne that could help me out with this 1 weekend or so, pm me if you can we can organize something.
ps: I dont know squat about soldering and I dont want to try lol
Cheers
  • 4 weeks later...
Gonna bump an old thread to say this fix worked on my car.
My car would run (what seemed like) okay when cold, but after it reached operating temperature, it would randomly die/not want to rev/drop revs/misfire/have a 2,500rpm rev limiter.
Car initially started have some minor issues revving out and making full boost, I thought it was the CAS as it was only doing it while hot. A CAS swap did not affect the car. The car gradually got worse until it started dying randomly.
I re-soldered both AFM, the soldering on the pins were a little weak. Re-sealed with Sikaflex.
Thanks again for this fix. I'll attack my R31's AFM when I get some time.
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
