It's time to ditch the 19s, and a friend has some stock 350Z alloys lying around, so can anyone see any difficulties that may arise fitting them to an R34 GTT?
As far as I can work out, they are the multi-spoked 17x7.5in front, 17x8in rear variety, offset +30 and +33 respectively.
Thanks in adavnce.
https://www.sau.com.au/forums/topic/113288-350z-rims-on-r34-gtt/
Hi oblivo....as for 350z rims they are 18" and I think either 7.5 or 8" wide.
They fit a R34 gtt fine (seen in person)....also have a look thru the classified section as some guy was selling them and had picks of them on his gtt.
Thanks silva...I was under the impression that there was only one set of 350Z rims.
All the 06 350Z's run 18x8's.
On previous year models, the entry level Touring spec had 17" rims with the staggered sizes listed above. The Track and the Roadsters ran the 18's, and the RAYS optional wheels were the same size, but forged for extra lightness.
And to answer the original question, if they'll fit an S14 Silvia (which I have seen) I can't see any issues putting them on a Skyline.
Edited by scathing
Thanks for the comments and that pic.
I must say they do look great on that 34, and they are the exact style of rim, but I'm fairly condident the ones available to me are the 17in variety... oh well.
I'm hoping they will make a dramatic improvement in weight over my concrete-blocks-with-rubber 19s. See how it goes.
If the rims are 17", then they're not that style. The 17" 350Z rims look like this.
  • 9 months later...
Hi there, sorry to hijack your thread,
But I can get 18" 350z rims from a freind who is about to buy one, and i wanted to know if they will fit a r33 4 door. I have no idea on the dimensions apart from 18", If anyone could help I would be greatful.
Cheers :thumbsup:
almost, they did fit right up on my skyline, but under acceleration they do scrape on the rear guards, and yes you need the guards rolled on a 32 to make them fit...
Those are the ones, There is nothing wrong with the wheels i have, but if i can go bigger why not! :laugh:
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
