A 2530 isnt all that different to the std turbo. (yes i know it will make a bit more power, and probably come on a little harder then std as well...but in the world of turbo upgrades it is pretty close to what the std turbo will do)
Thats not to say its a bad choice. Just that i would perhaps think twice about throwing $900 cams at en engine using a turbo as small as the 2530.
That said a friends R33 use to use a 2530, it had baby cams and a greddy manifold and it was still the best, and probably one of the quickest street cars i have been in...it was also damn quick as the track the couple fo times he was good enough to swap keys with me.
C'mon Troy!
A 2530 is heaps different to a standard turbo. Just cos you can find someone with a stock turbo making 200rwkw and someone else with a 2530 making 220rwkw doesn't mean that the second guy wont shit all over the first. We've all seen 2530 powered cars beating much higher peak powered cars.
C'mon Troy!
Sorry, i didnt really make myself clear. What i was getting at was perhaps you should think twice about using cams with a 2530.
I would highly rate the 2530 on the RB25. Like i said a friends old engine ran that setup and it was a briliant street car and very quick on the track.
What i was alluding to with regards to the size of it and the size of the std turbo is...ppl have shown that cams on a std turbo engine doesnt really do much at all. So was just cautioning that with a little 320hp turbo slapped onto the side of the RB25, cams may not give you the result you hope for...
As for 2530 on RB25...just make sure you have good tyres and suspension because they come on hard, and do everything you can to open up the exhaust as they tend to dropa few psi up high in the rev range
Ahh, that's a fair enough comment and may be true. I don't know anyone with a 2530 and cams but perhaps the higher boost capabilities would make them worthwhile where they are not with a stock turbo due to the boost restrictions imposed by it's fragility.
If looking at highflows check out some of the threads on them where we discuss the R34 and VG30 exhaust housings and how they are bigger making a highflow one of those better than a highflowed R33 turbo.
But that requires new manifold, an external wastegate...a hell of a lot of attention and expense for insulation of it and protection of all the engine bay ancillaries. Not saying its a bad choise, but a bit overkill for the power he is after .
Are you talking about the KKK or Garrett, cause the GT3071R needs no mods like that.... compariable to the HKS GTRS
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
    • Thanks for the details mate , for me I think being a daily driven and happy with a basic tune (630Nm and 310kw) . Seems to be working well I just put on a set of Michelin Pilot Sport 4 should help put the power down. I'm going to start looking a brakes and LSD in the future so I might reach out to you on options to upgrade the brakes. Cheers - Dee
    • I have a HR34 GT... RB20DE My speedo doesn't work! The rest of the gauges seem to work, fuel and RPM. I did not notice if my odometer was going up when driving last.  Any ideas? Speed sensor? Hopefully atleast... Gauge cluster perhaps? Or is that unlikely because the other gauges are working?   Any insight is appreciated. This is a rather new to me car. Lol
