Hi
Got an 95 R33 GTS-T. Got some k's on it but still runs great. Just lately have had this problem with it stalling after its been running for a short while. It just cuts out. Sometimes it will start up right away, other times it wont start for a few minutes, but it starts and runs ok even in traffic and hot weather. Any ideas?
A mate said he had something very similar with his Golf and it was faulty solder concetion on his ECU.
Has anyone had similar problem and any suggestion on where I can start looking.
Cheers
Most probably a faulty connection somewhere between ur battery and ecu. Car will stall if ECU has no power
Thanks for your reply. I don't thinks its battery connection though. I have very stiff suspension and the bumps would knock the poor connection around. It runs solid after 20min!! Still scratching my head.
Thanks though.
  • 1 month later...
G-day mate
Ive been having same problem it started last friday
with my R33 it turned ot to be my airflow meter i replaced it no more stalling..good luck
Hi just FYI
My stalling problem was my cam position sensor (or crank angle sensor- both same thing) It didn't like a certain temp while engine was warming up, but when it got past it, it was fine. Computer was indicating it was failing on fault diagnostic so I had it replaced and so far problem has disappeared!!
Cheers
