Ok options are either Friday the 14th of April....YES - This Friday...or Wednesday 19th
Both days are fine for me but I want to go on the day that suits most other people. This will be the first time the Elite 32 has hit the track so I want to see how she goes. New tyres and a 33 gearbox waiting back at the workshop just in case so nothing cept a wayward piston will stop me.
So what'll it be guys?...whose coming, and which day?
https://www.sau.com.au/forums/topic/113349-elite-goes-to-testntune/
  • Replies 86
There is a test and tune on this Friday...
Good friday??? Really...
Im keen to watch ya this Friday... Just need to pull the Mrs arm...
Whats the costs for spectators...?
Not sure on the cost for spectators, I think it's about $15.
Yes ben, hoping for 12's...if not a high 11 would also be acceptable.
Hey i dont remember this last time i went...???
Whats the go... All i paid bac then was $28 and i got 3 runs...
Quote from willowbanks website: You will also need an ANDRA Divisional Drag Racing license, available at the track. This is valid for the day of issue only.
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
