Ok options are either Friday the 14th of April....YES - This Friday...or Wednesday 19th
Both days are fine for me but I want to go on the day that suits most other people. This will be the first time the Elite 32 has hit the track so I want to see how she goes. New tyres and a 33 gearbox waiting back at the workshop just in case so nothing cept a wayward piston will stop me.
So what'll it be guys?...whose coming, and which day?
https://www.sau.com.au/forums/topic/113349-elite-goes-to-testntune/
  • Replies 86
There is a test and tune on this Friday...
Good friday??? Really...
Im keen to watch ya this Friday... Just need to pull the Mrs arm...
Whats the costs for spectators...?
Not sure on the cost for spectators, I think it's about $15.
Yes ben, hoping for 12's...if not a high 11 would also be acceptable.
Hey i dont remember this last time i went...???
Whats the go... All i paid bac then was $28 and i got 3 runs...
Quote from willowbanks website: You will also need an ANDRA Divisional Drag Racing license, available at the track. This is valid for the day of issue only.
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
    • I'm always a glass half full kinda guy. This will be a great project and the finished product will be awesome.
    • A local that insisted he learned from the best in Australia for RB builds managed to machine a head past the point of saving according to another shop and it dropped a valve too. Ghosted the customer and as far as I know nothing really happened to him. A coworker also recently told a story about owning a Porsche in Germany and running into issues with a dealer tech leaving scratches, oil stains, and missing parts all over his car. I'm not a master tech by any means but at this point I've seen enough expensive mistakes that I'd rather make them myself.
