you thinking its just taking too long to spool?
Well the 60ft times were 2.5 - 2.7 seconds so yeah....taking way too long to spool.
Give it too much the first time (4500 take off) and I was skidding through third
Gave it too little the second time (3500 take off) and I had to wait six months for boost
And in answer to your comment...NOS is not the answer!
What I really need is one of those super dooper rotary engines that has pistons inside and a 9 speed gearbox.
  • Replies 86
what turbo are u running on the rb20 now dan anyway??
GT2876RS with a 0.86 rear housing.
Don't worry about finding that turbo anywhere, I had it specially made.
I would like to change the rear housing to 0.63 to see which I like better. I just hope the 0.63 rear will hold out to 8500rpm like this one does but that's probably just wishful thinking.
I get fullboost (20psi) on the current one at about 4800rpm with cams, used to be 5500 before the cams went in.
With the other rear housing I should see fullboost at 2800 and have it carry all the way to 7000rpm which is a larger range anyway.
Can you get a .7somthing?? for that in between compromise??
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
