  • Replies 86
btw - i hit the drags tons.
You wont need any licenses etc.
Just make sure you have helmet and long sleeved clothes and long sleeved pants.
The $36 Entry fee or whatever includes 1 pit crew as well, so thats 1 spectator. So sort that out so someone is in with each person and it all gets cheap.
These days you can easily expect 10 runs if you want it....
mick
just let me know if u need it, shoei full face motorbike helmet, i bought it to go out to QR with. Dont think my car will be going for a run after thinkin about it so send me a PM, happy to just watch this time...
You clutch won't be ready for pick up until tuesday arvo so I can get it done on Wednesday for you.
As long as you give it 50km or so of easy driving to bed it in...you won't have a drama. Like I said...it's like a super sports organic so you won't have any problems with it. If you drop it in first thing on Wednesday I should have it ready to go for you before 11.
I also need a helmet but seeing as though I have such a doofus head, I am going to borrow one of a mate.
Looks like next wednesday might be the go for everyone at this point so I guess we'll make it then. Tomorrow is probably too little notice for everyone and I don't wanna head out unless I have someone there I know that might be able to drive me home when the g/box explodes lol.
Was there the week before last. Entry fee for racers: $36 per car( driver+1 spectator), Driver must wear long sleeves and long pants, plus a helmet. Actually you can share 1 between 2 cars, I did that last time since I dont have one. Just tell the lady you will share the helmet with ur friend.
should be about the same price for 2 spectators.... So I reckon go there and race better than just watch. Wednesday would be a better choice, since Fri would be more cars there. Last time, I was able to get at least 8 runs, but gave up after the sixth, since my car's so slow........ Will talk to you soon, Dan.
Edited by RYN26
No problem dan.. i'll still head out to support those running tho, wouldn't wanna lean on teh new clutch too much. PM sent about clutch booking too ;)
Not sure what size my helmet is, think its an XL/ 60cm give or take a cm or so..
I might be popping out there for this, give the sedan its first run down the strip. Most likely on the Friday, might be the end of the clutch though. . . . . oh well ;)
I will aim for a low 14, should be able to get the stocko down there somewhere.
I'm in for Wednesday!! And Dan I have a boof head and a good helmet if you want to share?? No cooties.... honest....
Oh, the car is fixed and it cost a lot less than I expected!! Cracked manifold and 3 sheared bolts!! All better now and runs even better!!
I could be interested for Wednesday..really want to see what the car can do before the new turbo ect! Hmmm what time do I want???? I guess for my first run I would be happy with making it to the end LOL
Thought it might be Dave. When I got mine it had the same thing and apparantley its a common thing for RB25s. They run sooo much better when its all fixed up. . . . which is to be expected I suppose.
Mine, the crack went right around and when I tapped it on the ground it broke in half!
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
