Here's a calculator for 1/4 mile times. not sure how accurate it is but I think it is pretty close. conversion is 2.205lbs = 1 kg
so a skyline being 1390kg is 3064lbs
http://www.robrobinette.com/et.htm
not bad...pretty accurate
kwinanna motorplex is a good 1/4 mile calculator.
These calculators are quite useless.....wait..... they are good for starting useless debates and arguments.
If you are serious about drag racing the information needs to be collected at the track, the actual track you want to race on and do well.
Whats the KW - HP ratio? I've forgotten? My old 32 GTR made 303RWKW last time I raced it, and it ran 11.135 @ 128mph. Isn't that about 430 rwhp? The calc said I needed 491 rwhp? Am I just a hell of a driver or what????!!!!! ;)
406.02hp - lets say you lose that much through the drivetrain - your calc isnt that bad.
Forgot to add that most calculators are at the engine. Most BASIC 1/4 mile calculators that use rwhp assume a % drivetrain loss which is a really bad thing.
Adrian
??? It states: "This calculator esitmates your quarter mile elapsed time (ET) when given the weight of the car and flywheel or wheel horsepower. A 17% driveline loss is assumed for flywheel HP."
I still reckon it's me!
1 hp is 0.74569 kw
so according to the calc...I could do a 10.6 with 500rwhp!!!! Now just have to find 500rwhp from somewhere :)
Just a note: You dont lose a fixed % through the drivetrain in ANY circumstance. The same drivetrain will lose say, 80hp with a 300hp engine as it will lose 80hp with a 500hp engine.
You don't magically get a drivetrain that eats more energy from the process.
So while 17% might work for your car NOW, if you increase the power from your engine by 200hp, the 17% wont apply.
Adrian
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
