running rb30det with orc triple plate and shitty rb20det box
looking at 33 gtst boxes. they no worries
but r34 gtt - does it work with push or pull type clutch
i aint very bright mechanically (or in many other aspects for that matter)
need to know if i can bolt up r34gtt box to my orc triple plate setup
not a teeny bopper dreamer, just need some advice.
cheers, mark
https://www.sau.com.au/forums/topic/113375-r34gtt-gearbox/
R34 box is pull, and you can get a thing to convert your push clutch to pull, but im not sure how well it works, but i know there are kits for this, orc mostlikely make one, as my twinplate clutch says it can be used on GTR and GTSTs but its a pull type, and yu can get a optional thing to make it push.
hope that kinda helps.
How is it driving with the tripple plate, is there even a smaller amount of play to find a friction point? espically in the 31 with it al the top of the pedal, how do you find it?
https://www.sau.com.au/forums/topic/113375-r34gtt-gearbox/#findComment-2093439
The 34 uses a pull clutch , the box is not any different, just the fork, pivot and the way the slave mounts on the bellhousing are different.
https://www.sau.com.au/forums/topic/113375-r34gtt-gearbox/#findComment-2093485
thanks for the answer fellas
looks like ill go with the usual and get a bloody r33 box. $$ but oh well. rb20det boxes serve me well but sick of breaking them.
as for triple plate, no play. bout 1/2 centimetre at top of clutch pedal. i find it ok because is obnly driven at track mostly so wheel spin is no drama. but taking off from traffic on a hill is terriblly hard without spinning wheels.
r33 box it is!!
https://www.sau.com.au/forums/topic/113375-r34gtt-gearbox/#findComment-2093924
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
