Item: 1970 Datsun 1200 CA18DE Unfinished Project
Item Condition: The car is in reasonable condition for its age, the undercarraige is very good with only a small spot of rust around the accelerator pedal, the body has a little rust around the usual places (rear guards and such), it has small dents nothing major.
Engine is in good condition with only 36000km on the odometer when it was removed from the silvia it was in
Reason for Selling: need the money.
Price and Payment Conditions: $2000neg
Extra Info:
5spd Manual (s3 TRX bluebird).
Custom engine cross member and gearbox Cross member and mounts to suit CA18.
Battery moved to boot.
5x 4 spoke dragways.
Exa radiator + Twin thermos and mounts.
Stanza struts with DBA slotted rotor upgrade but no callipers.
larger swaybar (22mm not 19mm).
VLturbo fuel pump.
Datsun 1200 Ute diff.
Sound deadener removed.
All glass and rubbers.
All interior trim is there except carpet although they are not in the best condition.
Most chrome in ok condition.
Any questions please call 0401165572
for pics please post your email.
thanks.
  • 1 month later...
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
