Item: 1970 Datsun 1200 CA18DE Unfinished Project
Item Condition: The car is in reasonable condition for its age, the undercarraige is very good with only a small spot of rust around the accelerator pedal, the body has a little rust around the usual places (rear guards and such), it has small dents nothing major.
Engine is in good condition with only 36000km on the odometer when it was removed from the silvia it was in
Reason for Selling: need the money.
Price and Payment Conditions: $2000neg
Extra Info:
5spd Manual (s3 TRX bluebird).
Custom engine cross member and gearbox Cross member and mounts to suit CA18.
Battery moved to boot.
5x 4 spoke dragways.
Exa radiator + Twin thermos and mounts.
Stanza struts with DBA slotted rotor upgrade but no callipers.
larger swaybar (22mm not 19mm).
VLturbo fuel pump.
Datsun 1200 Ute diff.
Sound deadener removed.
All glass and rubbers.
All interior trim is there except carpet although they are not in the best condition.
Most chrome in ok condition.
Any questions please call 0401165572
for pics please post your email.
thanks.
  • 1 month later...
    • Hahaha wow that was dead on! 🤣
    • Somehow we've reenacted this video completely seriously:
    • Nistune is pretty easy if all you want to do is change the injectors. TIM + latency change will do it. But I am very skeptical your mechanic has actually diagnosed the issue. As others have said flow/function test your injectors.
    • ^This. If you have to do injectors, and you have to buy bigger ones, get the smallest Bosch EV14 based injectors of the correct length that you can. This will be about 500-525cc most likely. The stock ECU (with Nistune) will be fine to run those. Then, use a Nistune. Tune it yourself. If all that you are doing is changing injector size, then you literally only have to change one number to do it, and then maybe some fine tuning of that number. You will not need to touch the fuel or ignition maps at all.
    • I don't know what those pipes are, but I'd say there is a good chance they are old school Japanese tuner because they are equal length and nicely made. Maybe someone like @Rezz who has direct access to japanese history might be able to help. Even so, I'm not sure what inspectors could check it to, they presumably are googling 30 year old japanese stuff same as us.
