when my 33 was hitting full boost whether it was stock boost or 12psi, it was splattering and backfiring. after reading alot of posts on the same issue, most people said to change the spark plugs and the sparkplug gap.
I bought new spark plugs for the car and it was still the same, if not worse. i then changes the gap from 1.1 to 0.85. it stopped most of the splattering but it was still doing it with the throttle fully opened, i then changed the gap from 0.85 to 0.7. still the same. i was talking to an engineer and he said the smaller the gap the faster it sparks, but the spark is not as powerfull. he said that my car was also running lean due to the build up on the sparkplugs. which then lead me to beleive that it was a fuel managment problem which could put a dent in my wallet. after thinking of what could be making the engine run lean, the cheapest possible thing to change was the fuel filter. after removing the fuel filter we found that it was quiet dirty and had alot of build up in it. he said this is why it was running lean. so after a new fuel filter was installed. the car runs perfect from 8psi to 15 psi. So if anyone seems to have this splattering problem instead of going straight out and upgrading the fuel managment check the fuel filter and spark plugs. this could save you $$$$
spark plugs: ngk = 6 x $4
fuel filter = 1 x $18
cheers, amd i hope this fixes your fuel problems.
https://www.sau.com.au/forums/topic/113412-4000rpm-splattering/
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
