how rich are u running it cos that seems bout right..wat fuel are u using
using bp ultimate 98, oh okay i thaught would get more well this time just now i got 310 out of the tank.
the tune on the wolf is pretty rich if i give it too it but safe so i am happy, comparing to other wolf maps mine is a bit more up than other,but just wondering what other r32's get out of tank???
iam using nismo 550cc injectors, wolf 3d, t3/t4 high flowed turbo and all other usual mods
Autronic SMC - 510cc injectors - T3/T4 - 14L/100km doing multiple short trips (read cold start) with zero spirited driving.
17L/100km if I let it come onto boost slightly during shifts (2psi).
Only got to do one highway run to Phillip Island and back and it had 380kms with 1/4 tank left but the box threw a bearing as I got home so dont know what it would have got.
in my rb20 s14 i got about 30mpg highway and 25 city...
if i romped on it the numbers obviously go down but not as much as you would think, got bout 20mpg being an ass round town on boost alot.
had chipped ecu,550cc injectors, gt30r/hks 3037 turbo,z32 maf.
Autronic SMC (shit cold start, needs more tuning), Apexi RX6 highmounts (17/21 psi), zorst, usual shit. Currently get approx 300 - 350, driving mix of hwy and city. Guess you could say its gets both a cruise and a hard time time. Got cams, 700cc inectors/fuel rail an reg to go in, wonder how it'll all pan out then...
yeah after the weekend i got 325kms out of the tank but doesnt seem that far off the mark then, running 16psi daily and is a mixture of city and some night time driving
I have an R32 GTS-t with the following mods...
FMIC, 040 Pump, POD, 14PSI, 3" Ex + Dump, 18" Rims (believe it or not but they can make a big difference in economy) Dr Drift retuned ECU
I generally get about 300-350 per tank normal driving - occasional squirt. Was a lot worse before the tune as it was running megga rich!
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
