Can anyone recommend me a good place/site to get a good quality carbon fibre bonnet for my R32 GTR?
I was looking for a full dry CF one. But have only found ones with a CF coating on fibreglass. Is there much diff in weight? or any other differences? Any help appreciated greatly. Thanks
https://www.sau.com.au/forums/topic/113446-carbon-fibre-bonnets/
try customcarbon.com.au in QLD, excellent quiality proper carbon bonnets, they have em off the shelf for 32 GTR. Thats where I got mine from...couldnt be happier with the finish!!
cheers
Berin
edit: after trying the site it doesnt seem to be loading on my pc?? only other extra info i could give you is it's in Virgina QLD.
http://www.skylinesaustralia.com/photopost...500/ppuser/7879
wouldnt recommend buying 100% carbon unless you have the funds to do it as the weight diference is very very small between that and carbon coated fibreglass one.....just my 2c anywayz
yea thats wat i wanted to know in my first post.. the weight diff
anyways ive decided against getting the CF hood for now.. money better spent elsewhere..
besides the rice factor wont really benefit my car atm heh
CF bonnet usually uses epoxy, it's flamable. we use hi temp resins for cf bonnets, the same as that used on CF mufflers.
unfortunately there will be no cf bonnets until further notice. due to cf shortage.
if you want to lighten your car up, we can shave off 20kg- 100kg depending on how far do you want to go.
100 cf are very dangerous indeed, no one uses them, it's electrical conduction are very severe. that's why fiberglass overlay are important on cf parts to make them less snappy on impact and to prevent electrical shorts......
and for front lips, Fiberglass Flexi are more durable than CF lips. same with bonnets.
no one except for nissan and there genuine R34 bonnets.....
i am tipping that the reason most of you dont make them use only carbon is due to the cost.....
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
