  • Replies 125
Posted Images
Hi Mate,
Engine has done 90,000kms since I bought it, and 170,000 is on the car. The engine was very strong, Fatz drove it the last day it was running and said that all it needed was a bigger turbo... actually the only reason I pulled it out was because we had the bigger engine pretty much done, and I am really not 100% sure I want to sell it, as I'm thinking about keeping it as a spare engine if I lunch this one.
Overall condition... it always got serviced less than 5000kms, I always run top oils, make sure that it is running good fuel and looked after it extreamly well, I was getting all the stuff through sponsorship... Never ran more than 0.8bar of boost.
Never had a problem with the engine, except for a cracked exhaust manifold, that is it.
Engine was sealed before I took it out of the car.
Let me know if you want some other info, or more specific info.
Cheers,
Dan.
sorry for the hi-jack, free bump I guess
Just wondering whether your mspec front bar came with the 2 grills on the bottom part or if you bought them somewhere.
Or if you want to sell them to me I'm only 15 min drive to Penrith on the m4 :domokun:
I am selling the with the bar, which should be going in the next 2 weeks. They came with the bar, might try jsut jap or SSS automotive?
Hey, Thanks anyway dude.
If it's not too much trouble, could you see if the grills have any product or number code on them? I'll try to order them through nissan lincorp because nobody else has got them, a product code would really help.
All the best mate
Cheers
