series on or series two ecu
does any one know how to tell the difference between them as what the numbers stand for
or know where i could find this info
Check the Nissan Part number against the following list from FAST.
23710-21U00 RB25DET S1 Manual 1993-08 to 1993-09
23710-21U01 RB25DET S1 Manual 1993-09 to 1994-04
23710-21U02 RB25DET S1 Manual 1994-04 to 1994-07
23710-21U03 RB25DET S1 Manual 1994-07 to 1995-01
23710-21U10 RB25DET S1 Auto 1993-08 to 1993-09
23710-21U11 RB25DET S1 Auto 1993-09 to 1994-04
23710-21U12 RB25DET S1 Auto 1994-04 to 1994-07
23710-21U13 RB25DET S1 Auto 1994-07 to 1995-01
23710-21U60 RB25DET S1 Manual 1995-01 to 1995-08
23710-21U61 RB25DET S1 Manual 1995-08 to 1996-01
23710-21U70 RB25DET S1 Auto 1995-01 to 1995-08
23710-21U71 RB25DET S1 Auto 1995-08 to 1996-01
23710-13U00 RB25DET S2 Manual 1996-01 to 1996-06
23710-13U01 RB25DET S2 Manual 1996-06 on
23710-13U10 RB25DET S2 Auto 1996-01 on
Wow, there was a lot of changes to the S1 ECU, 6 versions in just 2 and a half years. :domokun:
Edited by PlasticStan
thanxs mate i can tell what computer im running now as mine went arse up and the mechanic just got a second hand one and runs soo rich now there must be a drama with it
this fast book or whatever is it online or do you buy it from some where
  • 4 years later...
in the general automotive section. probably a few pages back now.
it doesn't really matter though. in the r33's the series 1 and series 2 ecu will work in either model (i have personally done this). some people think that the series 2 has the ignitor built into it but they are wrong. the series 2 have the ignitor built into the coils rather than having a seperate ignitor like the s1.
look at the number on the stamp on the front of the ECU. It will have, for example, MEC -52723
If it is MEC-5*** it is a series 1 ecu
If it is MEC-6*** it is a series 1.5 ecu
If it is MEC-7*** it is a series 2 ecu
as aforementioned, they are actually able to be interchanged between the different series anyway. Not really sure on the effects of this though.
just be aware of the auto/manual bit though as detailed above. Iv heard this can influence idle and a range of other things.
good luck.
Edited by jjman
i see i see. i thought the ignitor was built into ecu on s2 also. as do many people. i will have a look at the coils. yet another myth busted.
yeah it's a common myth that the ignitor is in the ecu but it isn't, otherwise the coilpack part numbers would be the same and there would be 2 different pfc computers for the different series. but there is only 1 pfc type for the 33 and 2 different coil pack types for the 33.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
