hey, ive accidentally connected either the positive or negative of wire of the boost gauge to the wire grounded from my car and didnt realise >< stupid i know but getting that aside. Ok now for the problem, now none of the lights thats supposed to be turned on, on the first twist of the switch arent turning on!!! the dash, tailights, parker lights and the plate number light! plz i need help! and whether the incident was the cause
thx
-jp
https://www.sau.com.au/forums/topic/113538-help-needed-for-my-lighting/
Check the fuses in the boot next to the battery, 2nd from front is the 10A fuse for dash lights and sidelights illumination. >_<
In the future, you should disconnect the -ve wire from the battery when doing any electrical work, and you won't have any problems if you accidentally ground a live wire. :domokun:
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
