Which Engine Oil ?
Mid_Nite_R33
  • Replies 92
hey,
What good engine oil would you recommend for a fairly stock R33 gtst?
cheers
Sorry just to be more specific,mine is a fairly stock R32 gstst and I use Motul 4100 Turbolight 20W50,
Im willing to spend up to $100, which motul though?
You can choose:
Motul 4100 Turbolight 20W50,5l(thicker oil)
Motul 4100 Turbolight 10W40,5l
Its great stuff, any import workshop would recommend it..
I think its priced about $45-50
You can choose:
Are you able to get Mobil delvac 1 5w40 over there? That is one pretty strong oil (group IV/V) with loads of anti-wear additives.
Edited by Trex101
Are you able to get Mobil delvac 1 5w40 over there? That is one pretty strong oil (group IV/V) with louds of anti-wear additives.
Im gonna go to bursons tommorow if they're open and see what they got out of the mentioned oils...
alot of people use castrol 10W-60 formula R.
supercheap has 20% off today as its easter.....
otherwise motul fully synthetics are very good.
That's too thick for street use unless it's for track or autocross... even for that you got to baby it till up to temp before flooring it.
Interesting read by Dr AEHaas
Thick or thin oil?
I picked up some shell Helix fully synth 5-40 but haven't put it in yet, will it be OK?
SHU are actually quite avg, make up of mostly group III oil. There's some pretty strong oil like Mobil delvac 1, Motul 300V, Redline street engine oil and Royal Purple.
i will be buying motul 8100 XCESS for my next oil ,, havent used it before but heard it is very good
anyone else agree with me on the 8100 ?
-JD
Edited by JD-33
Thick or thin oil?
you have to remember that alot of people don't just baby their cars but regularly thrash them either drags/drift, general spirited driving...
and australian conditions are pretty warm compared to the USA where it snows in winter thus we can use thicker oil.
-JD
yup, thats a good oil. even better is the Motul 300V chrono but pretty expensive :domokun:
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
