Which Engine Oil ?
Mid_Nite_R33
  • Replies 92
Hi guys I thought I should add a story that I have
Recently my car started losing oil pressure, It was fine on cold start but as you drove around the pressure dropped to almost nothing and I was using a heap of oil as well, I was thinking the worst, till I read TO4GTRs thread about keeping that RB alive.
I had Motul 10w40 turbo light in the car and as the temperature built the oil simply couldnt cope and broke down becoming too thin for the pump to push properly
I changed to penrite 5w60 and problem solved so thnaks to dave for pointing me in the right direction, the penrite is about $20 cheaper too!
  • 4 years later...
What are peoples thoughts on PENRITE 5w60 Fully Syn?
I just ordered mine $120 for 5L. Guy at Supercheap showed me this:
http://royalpurple.com.au/article_images/oil_test_article.pdf?ptl=hot_rod_article.php?ptl=articles_oil_supplement.php
PDF file showing a test run by a magazine. Unsure whether to believe it or not(could be a big marketing ploy). Motul didnt do too well in that test, and neither did Mobil/Elf..
For anyone wanting more info it's all covered in the oils sticky whistling.gif
I used motul 8100 xcess, and loved it, until sougi s6000 came into my life. But that's dead and gone now sadly. The nulon "fully synth" was pretty good for a grade 3, cost a bit though when 4100 turbolight is cheaper.
Not sure if it's the same for gtr's, I'd imagine it is, but 10w40 is usually about right for aussie conditions with the normal number of kms on it.
There are a few conditions that have to be met by the viscosity of the oil, and it's all compromises:
-On start up it has to be thin enough to be pumped quickly to moving parts, yet thick enough to provide decent protection when there.
-You want it to be thick to provide decent protection for valves and cylinders, but thin enough to drain from the head to the sump properly.
They're the two big ones. 10w40 is usually accepted to be adequate for australia. The original nissan oil was 7.5w30, but many kms have been done since then and, more importantly, the weather conditions are different here.
How about Penrite Sin 5 (5W-60)?
I have a standard R32 GT-R, probably has like 120,000 km
Nissan recommend 7.5W - 30 in their books.
+ the R32 being engineered in the late 80's to early mid 90's, it would most probably be a Mineral Based engine oil.
I have used:
- Martini Racing 10W - 40, Full Synthetic = Very nice!
- Valvoline 20W - 50, Semi Synthetic = Bit too "thick" and car ran sluggish.
- Shell 15W - 50, Semi Synthetic = Was ok for the first 1000 kms then turn to shit.
- Mobil Synthetic S 10W - 40 (2000 X 2) Semi Synthetic = Best so far from what I have used and just before an oil change the car still runs well, once changed = Very smooth.
My mechanic has recommended Mobil Synthetic S and the car is running fine.
I think the Mobil has the closest viscosity to what the R32 GTR should run, but everyone has their own personal preference and recommendations.
Different cars will have different recommendations + if you car is modified (Mild to Heavy) and having internal mods done, you'd run a Full Synthetic as the engine will have different tolerances to stock and lightly modified cars.
Just changed my oil today. Oil pressure on cold start up is down to around 5bar(7bar before). I used to run Elf fully sun 15w50(I think). Im also using a Veruspeed Nismo filter as well.
I noticed the engine was more responsive. I guess I'll keep an eye on it.
EDIT - I used Penrite 5w60 Fully syn oil. Bloody exp - $130/5L.
Edited by Ultimategtr
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
