G_day mate
I use Mobil 1 5w-50 its 65.99 at autobarn
If you buy a oil filter and pod ya get 15% off
i got a pod on special for $30
oil filter for$8
Mobil 1 oil $65.99 gran total of $104 all that for $88 worth a look mate.....
  • Replies 92
you have to remember that alot of people don't just baby their cars but regularly thrash them either drags/drift, general spirited driving...
and australian conditions are pretty warm compared to the USA where it snows in winter thus we can use thicker oil.
In USA they do have summer too. Places like Texas or New Mexico are pretty damn hot during some part of the Summer.
trex101... you seem to know your oil...
do you recommend motul 4100 turbolight 10w 40?
Motul 4100 is semi-synthetic, i couldn't find it's product data sheet so i don't know how's it cold flow or HTHS. IMO, i would choose a oil with good startup flow (depend on ambient temp) and high HTHS, how you know the figure? Check out it's product data sheet.
what is the viscosity range of the motul 300v ?
The 300V range has quite a few viscosities to choose from, but the 300V chrono is 10W-40
here's the list:
300V LE MANS 20W60
300V COMPETITION 15W50
300V CHRONO 10W40
300V POWER 5W40
300V POWER RACING 5W30
300V HIGH-RPM 0W20
300V 4T COMPETITION 15W50
300V 4T SPORT 10W40
300V 4T FACTORY LINE 5W40
see -> http://www.motul.com.au/product_line_up/4s.../4stroke01.html
yes, but those people that live up north close to canada don't have to worry about very hot climates and so would choose an oil that is suitable for very cold conditions and moderate temps.
People living in hotter average climates will choose a slightly thicker oil to match the average temps.
You can't expect people to change oil depending on what season it is, you just chose something that suits the average tempreture and driving style of where they live- you don't have to be exact with the viscosity, as long as the oil is good quality, changed regularly and is 'about right' with the viscosity, its good enough. :bunny:
I use Mobil Synth S 10W40.
Used it in my rotor, and now use it in my 32 gtst. Don't have any probs. Cheapish ($30), but not nasty. Just bought another 2 x 5L yesterday at Repco's sale.
Fixxxer
You should have heard my mechanic go off at me about that stuff, mobil 1, penrite stuff etc. He said ONLY motul as its easy enough to get now, and not all that exxy. The turbolite stuff being fine for resonably stock cars. He does stock it, but he also tells me to go get it from autobarn as its cheaper than him selling it to me. So he isnt getting anything out of it.
here's the list:
300V LE MANS 20W60
300V CHRONO 10W40
300V POWER 5W40
300V HIGH-RPM 0W20
300V 4T SPORT 10W40
Hi mate, u reckon 15w50 is too thick for street use for a R33 GTR? im currently using Motul 4100 10w40.
If you choose 15w50 oil, you must not floor your ride for the first 20min before your engine oil is up to temp. Anyway 15w50 will cause more startup wear, not suitable for short trip or city driving.
15W is the cold viscosity which isn't hugely different to 10W - the difference in wear will be minimal
if your having any problems with oil consumption then a thicker oil will help. A 15w-50 is good for summer use/thrashing, and if you get a full synthetic like motul 300V its better then the 4100 as thats only a semi-synthetic so despite the thicker oil a 15w-50 will be better then a semi 10w-40 as the motul full synthetics use ester component in the oil which greatly reduces startup wear. Just look at their website it explians the benefits of fully synthetic ester oils :)
ester benefits -> http://www.motul.com.au/fact_sheets/estel_oil.html
thanx guys, i might give the 300v 15w50 a try next time, see how i go.
I know with my FTO which rev's out to about 8k I can't use more than about 30 (operating) in it. If u use a 50 (good for stopping tappets etc!! which is good) is it too thick at high revs...I mean we usually rev it out when we get it some...
Although I'm not sure if 40 or 50 will be much different..maybe the Motul oil is better..15W-50 would stop a lot of tappet noise for sure...10W-40 seems pretty normal though...would be a low enough viscosity to be safe at high revs.
KJ
KJ
Thinner oil will has less drag on the engine component during operation. It will actually increase hp and improve your FC with thinner oil but the cons are lower HTHS at 150'c. This is the oil thickness when the oil reach 150'c during load or stress.
The best oil would be a thin 30wt oil with high HTHS. It will give you good hp and FC plus great protection during full throttle run.
IMO Redline 5w30 with HTHS of 3.8 are make up of mostly polyolester (group V) base stock couple with killer additives are the best money can buy. The oil film strength at high temp are stronger than most 40wt fully synthetic oil in the market.
FYI Mobil 1 fully synthetic 0w40 HTHS are only 3.6
true, and if you get a full synthetic 15W then there will be no difference :D
Whether an oil is synthetic or not makes no difference to the viscosity. A 20W50 mineral oil will be exactly the same as a 20W50 synthetic oil. How long it stays like that is a whole different issue, however. Use a synthetic oil as it will keep the motor cleaner (ie allow less black gunk to build up) when the thing gets exposed to high temperatures.
Secondly there is a considerable diference between an oil with a low temp viscosity of 5 and one with a low temp viscosity of 10. Try it next time you buy some oil. Pick up the two different containers in the shop & slop them around a bit. You will be surprised....
Lastly, it will take longer to fill the motor with say a 10W60 Castrol than a 5W50 Mobil. Have just done this (I used some of both as I had some Mobil 1 left over) & I can assure you there is a large difference. This is a good indicator of the diference in the oils viscosity.
Semi-Synthetic or Full is the go and you won't go wrong with the Motul 4100 Turbolight although I would use the 10W over the 15W, especially in a street driven turbo engine. Check your factory engine requirements.
I've been using Penrite HPR10 for over 60,000km and it's fine (RB25DET).
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
