Thinner oil will has less drag on the engine component during operation. It will actually increase hp and improve your FC with thinner oil but the cons are lower HTHS at 150'c. This is the oil thickness when the oil reach 150'c during load or stress.
The best oil would be a thin 30wt oil with high HTHS. It will give you good hp and FC plus great protection during full throttle run.
IMO Redline 5w30 with HTHS of 3.8 are make up of mostly polyolester (group V) base stock couple with killer additives are the best money can buy. The oil film strength at high temp are stronger than most 40wt fully synthetic oil in the market.
FYI Mobil 1 fully synthetic 0w40 HTHS are only 3.6
Thanks for the info...howveer I'm not sure what HTHS means. Currently I use the 300v 5W-30 in my FTO and plan to use the 10W-40 in my R33...I'm intrested to understand what HTHS means. - High Temp/High Sheer?? not sure exactly how thsi relates...I'm sure u will let me know :P
I agree that the redline product is awsome...although its quite expensive form memory...
  • Replies 92
I have found that since I got my skyline the oil seems to get black very quickly. Im talking it was changed when I got it and its really black now after like 1500-2000k's. Is that normal ?
Are you using open pod filter? If yes, change back to stock. Open pod let in more dust so oil get darken quicker.
Edited by Trex101
Thanks for the info...howveer I'm not sure what HTHS means. Currently I use the 300v 5W-30 in my FTO and plan to use the 10W-40 in my R33...I'm intrested to understand what HTHS means. - High Temp/High Sheer?? not sure exactly how thsi relates...I'm sure u will let me know :D
Yes, HTHS stand for High Temp High Shear using ASTM D4683. It the oil viscosity under hydrodynamic lubrication at 150'c, a good indicator of (under hydrodynamic lubrication) wear protection in high load and stress situation. HTHS will drop if the oil do shear over useage/time, so choosing a good oil is very important for engine wear protection.
Synthetic oil do normally shear less than mineral but only UOA (used oil analysis) can tell the condition of your oil and engine.
Do u do lots of short trips like under 5 mins if so i find the oil can go black very quick , If u do no short trips and every time the car is started it runs for over 1/2 hour the oil seems to stay more clear
I have found this in a few cars that I have owned , i use to live about 40mins from work and my oil would look great up to 5000km now i live 6mins from work and my oil go black very quick , has anybody else notice this???????
Get the best oil you can afford. Synthetic if possible!
0w/30 - 5w/30 - 5w/40 - 10w/40 they will all do the job.
The best thing about synthetic lubes is not the base itself but the amount of additive they can carry!
Inside info for ya :)
DONT GET CAUGHT UP IN MARKETING B/S :D ALL OF THE TOP BRANDS ARE GOOD!
how can a pod filter affect oil quality? If a pod filter is properly oiled it will filter the air just as good as paper elements.
This is what the filter manufacturer wants you to think. More airflow will result in more dirt ingestion even with well oil filter.
Oh don't overoil the filter, you may damage the AFM sensor. It's good preventive practice to use plastic safe electro contact cleaner to clean the sensor.. prolong sensor life and accuracy.
I recommend Motul, its a bit expensive but very good, Autobarn stocks it...
if you're after a high quality oil, Motul definately. Mine is stock at the moment, but after i had the major service done to it, all fluids gear, diff, engine were all replaced with Motul and I couldn't believe I could actually feel the difference in driving, especially in the gear stick!
thats not exactly true. More surface area allow for more airflow with a given restriction. I use UniFilter pod filters they have heaps better filter protection than paper and most other pod filters...
u wanna know the specs (most engine wear is caused by dust >> 15 micron)
Paper filiments have holes that allow dust of 30-40 microns through
Oiled paper << 20microns
Cotton Gauze -<< 45 microns
Unifilter Oiled Foam << 4 microns
now for restriction ratings..
Paper as a base rating
Oiled paper ~2% more restrictive
Cotton Gauze - ~25% LESS restrictive
Unifilter Oiled Foam ~24% LESS restrictive
Unifilter is used by leading racing teams...its Aussie made and simly one of the best designs around.
Edited by khunjeng
Some interesting read on air filter.
Autospeed
BITOG
Autospeed
BITOG
as usual they are not really correct...but results off all my CAI setups show (on my fto) has 7kwatw more with the new pipe form the pod to the TB and with the new snokrel from the grill into the boxed area. I have seen similar gains with my CAI setup on my R33.
never just put a pod and sit it in the engine bay...total waste of time as they were saying. box it up...get more air into the area etc..its CAI after all...
lol now how is this about oil?? :D
Edited by khunjeng
After reading all your rants... its still doesnt answer the guys questions...
What is a good oil for what he drives?
I am in the same delima, i have an R33 GTST its pritty stock, puts out 174RWKW and i ocasionally go to a drag meet and once every three months go to a track day.
I serviced my car about 2000k ago, but i am going to track day on the 29th. I am planning to change the oil so i have a fresh batch for oran park.
What should i use so my car lasts the day but also the oil which has been used on the day will also last another 3000Km's?
kthanxbi
IMHO - just use Mobil 1. It is good oil, good viscosity range, good price.
If you are going to a track day, 2000km old oil is fine. Keep an eye on the oil temp (if you have a guage) & check the oil for blackness (from blow by) when you get home. Beyond that there is nothing particular to worry about other than keeping the oil level to the correct level.
You don't need to do anything special about changing oil for the drags as the thing is only on throttle for 11 & a bit seconds at a time.
hmm, so how does the air actually dirty the oil, presuming a good engine with not much blow-by?
This is a interesting article by Wearcheck on accelerated wear cause by dirt/dust ingestion. It will explain more on how the dirt is ingest and wear it cause.
Wearcheck
Edited by Trex101
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
