as topic states, i have rough idle, it reves up between 300rpm and 1200rpm up and down, up and down, and eventually it gets back to normal. its been happening for the few days.. i will try cleaning the AFM and throttle tomorrow...
but i also noticed a ticking noise from the exhaust manifold, i think it started out as a whistling sign and then in the last few days, its been ticking everytime i rev it anywhere above 1000rpm. ive been told it was a leak on the manifold that makes the ticking noise, but i dont have any ideas
the car is also "boost spiking" in a sense that after 4000rpm, there is a flatspot till 5500rpm, at the same time, boost will creep up from .7bar to .9bar and drop back off at 6000rpm to .7 again
anyone have any ideas?
Edited by Kryostaisis
You can be comfortable your exhaust gasket is gone. That can also cause the sporatic boost control. Don't leave it too long as it can burn an exhaust valve by giving it a hard time for a long period of time with the exhaust gasket leaking.
The idle is not generally effected as bad as you seem to suggest it is though when the exhaust gasket is gone. Sounds like a vacuum problem to me in combination with the exhaust gasket. Do one thing at a time though and get the gasket repaired.
I read sumwhere that a ticking noise means knocking....prolly sumthing causes your engine to burn really lean..esp with boost control problem you are having...need to verify this tho..I'm not very sure
nah the ticking is a leak, im pretty sure about that, although ive been told that my flatspot/power loss problem might be due to my knock sensor being damaged and so it may be retarding the timing... but im not sure if thats the case, im going to fix the leak first and see how i go from there
You have an exhaust leak - Get your manifold off and replace the broken gaskets
I'd grab the Tomei metal exhaust side gasket set, but you could use factory type gaskets if you preferred.
anyone got any idea on how much manifod gastkets cost? should i use gasket glue aswell as a new gasket? or can i just use the gasket glue on the one i have now?
OEM exhaust gasket is about $85
edit: hmmm.....that might have been at trade price, so say ~$100
Edited by Lazy-Bastard
any other ideas? im pulling out the manifold tomorrow and hopefully have it back up and runnin by wednesday
My bet is you will find one or more head to manifold studs broken, or the threads pulled out of the head. Probably broken ones though. Drill the manifold holes bigger, so the manifold can expand lengthwise without putting a shear load on the new studs. To get the broken bits out centre drill them (I made a guide plate to bolt on the good studs and a collet in a hole centred on the broken stud, to centre the drill bit automatically). Drill to a size less then the ID of the thread root, and to a size where you can tap in a splined (Torx) bit, with enough purchase to allow you unscrew the broken piece of stud. Buy genuine ones, don't use bits of sawn off set screws!!
ok, ive started to pull off the manifold, i have still left the turbo hanging off teh manifold, was kind of hoping i wouldnt need to remove it, but i guess i have to now that i cant get to the other nuts.
just one quick question, i can notice there are dark spots around the manifold, which suggests that there is a leak, at the front end of the manifold(nearest to the headlights) there is a leak, but i think its due to the bolt being very loosely put on, as i could undo it with my fingers.
at the back of the manifold, there is a really dark patch of carbon deposit, and the noise did seem to be comming from the bck...
my question is, is there supposed to be 12 nuts and studs altogether for the manifold?
if so, i think my last stud and nut closest to the firewall has snapped off, god knows how, but how am i supposed to get a new stud? where can you get them from?
ill keep everyone posted.. hopefully this will solve my flatspot problem
there's 12..
they're $2.85 each from nissan.
Its usually the front and the back ones that snap off, yup.
i'd be spending the extra effort taking the turbo off, it will save you time and make it much easier to do what you need to do.
yeah i had the same problem....was the gasket.... :( my advice is WD40 the bolts b4 undoing them...otherwise u r likely 2 snap a few and that gets F$#%ING annoying.... :(
ive taken most of them off, ordered a few new studs, 2.25 each, but the gasket is 130bucks!!
then only problem i have is that the stud closest to the firewall has been snapped (most likely for quite some time now, as ive been experiencing the boost creep and flatspot for quite some time now), i have no idea how im going to get a drill into that to undo it, anyone have any ideas?
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
