Apexi 440cc Injectors, Grex Oil Cooler From R34 Gt-t
100% hear you. I won't defend them but I will defend my ability to work twice as hard to keep them running. 馃ぃ
By robbo_rb180 路 Posted
A mate had this style seat from SAAS years ago and they were pretty comfy but the quality was not great especially after a few years. Have you looked some 86/BRZ seats? the seat warmer is great and I use it a lot. I just drove almost 2hours and no issues with comfort. -
By soviet_merlin 路 Posted
I always find it both fascinating and educating seeing you go through all this. It's a bit like "BMWs are great. Except with one massive caveat: as long as you fix this two page long list of things where components are broken by design" Every now and then I consider getting a BMW. And then I read your posts and think that maybe the RB life is not so bad after all -
For the record, I hate the colour. Even if I'll never see it again, I know its in there.
This is another issue I'm fixing. This little valve stops all the oil from draining to the sump when the engine is turned off. What happens eventually is that the engine is a little noisy and has the oil pressure light on for a few seconds after turning it on. Basically it takes a few seconds to build the pressure when all the oil has drained. This valve is a non serviceable part and is attached to the oil filter housing, BMW suggests to replace the entire housing if this valve fails. As it turns out this valve can be removed and that means you can get an aftermarket replacement, which I did. The failure, for me at least is that the valve doesn't seat properly after a while, which I've demonstrated. The new one is a ball end and always seats properly.
