Hey Everyone,
I have a Motorola V3 mobile phone for sale. It is in good condition, has a small scratch on the front screen and a worn keypad. It is a little over 6 months old, and has been looked after very well. Selling due to upgrading. Comes with wall charger, handsfree earpiece, software CD.
Looking for $150 or nearest offer.
Located in Canberra but can post within Australia at buyer's expense.
The RAZR V3 - an ultra-slim, metal-clad flip phone with great looks and minimal compromises. The RAZR V3 is crafted from aircraft-grade aluminum and features impressive new technology such as a chemically etched Keypad, along with a quad-band internal antenna. All of these lead to a device that's only 14mm thin. The RAZR V3 is not just a pretty face, though. Motorola has integrated almost everything we could ask for in a modern clamshell with an integrated VGA Camera, 2.2" 64K color screen, speakerphone, color external display, and even long range Bluetooth. Furthermore, the RAZR V3's multimedia capabilities are amongst the best available, with a 3D graphics engine for Java games, MP3 Ringtones, and video playback.
Features:
2.2 inch 176 x 220 pixel 64K color TFT
96x80 pixel 4k color CSTN CLI
VGA camera with 4x zoom
Video playback only
MMS/EMS/SMS
WAP/xHTML
Bluetooth
Java (MIDP v2.0) with 3D Graphics
xHTML browser
22kHz polyphonic speaker with MP3 ringer support
EL keypad illumination panel, nickel-plated copper-alloy chemically-etched keypad
GPRS
SyncML
Calculator
Alarm Clock
Calendar
Dimension (WxHxD) 14mm x 55mm x 98mm
Weight 95g
Edited by NathR32
https://www.sau.com.au/forums/topic/113577-motorola-v3-silver/
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
